ADVANCED ENGINEERING
HEAVY DUTY
Technical Data Sheet
Put-Ups
E
xtreme Abrasion And
Cut Resistance
R
esists Gasoline, UV,
Solvents, Salt Water
And Chemicals
B
raided From .15 mil
PET Monofilament
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
3/8”
5/8”
1”
1 1/2”
2”
3”
4”
HWN0.13BK
HWN0.38
HWN0.63
HWN1.00
HWN1.50
HWN2.00
HWN3.00
HWN4.00
1/16”
3/16”
5/16”
1/2”
3/4”
1 1/2”
2”
2 1/2”
3/16”
3/4”
7/8”
1 1/2”
2”
3”
4”
5 1/2”
500’
500’
250’
250’
250’
200’
100’
100’
125’
100’
75’
50’
50’
50’
50’
50’
BK
3
3
3
3
3
3
3
0.27
0.82
1.10
1.60
2.50
3.40
4.20
4.20
50% Thicker For The Really
Abrasive Jobs
When your application calls for more
protection than our 10 mil products
provide, our 15 mil HW is the ideal solution.
HW is commonly used in industrial and
marine applications where extreme abrasion
protection is critical. The durability of HW
makes it ideal for protecting hoses and cables
that have to withstand constant contact
with rough and abrasive surfaces.
Cut Cleanly
Hot Knife
HW is the perfect solution for use on chains
and cables to protect painted or laminated
surfaces from scuffing and wear.
Material
Polyethylene Terephthalate
HW protects trailer hitch harnesses from
abrasion, flying debris and UV damage
without affecting flexibility or trapping
moisture like convoluted tubing.
Grade
HWN
Monofilament Diameter
.015”
Colors Available:
Drawing Number
TF001HWN-WD
Clear (CL), Carbon (CB), and Black (BK).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Colors Available:
3 = BK, CL, and CB.
HEAVY
DUTY ENGINEERING
ADVANCED
Melt Point
ABRASION
Medium
Rating______________________UL94VO
Maximum Continuous
Mil-I-23053
257°F (125°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
72%
Two Broken Strands
200 Test Cycles
Braid Worn Through In
One Direction, In Several
Places
700 Test Cycles
Material Destroyed Braid Worn Through In
Both Directions
950 Test Cycles
Pre-Test Weight
5,262.7 mg
Post-Test Weight
4,979.9 mg
Test End Loss Of Mass
Point Of Destruction
239.3 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ .015”
ASTM D-204
Flammability Rating_____________UL94
Recommended Cutting______ Hot Knife
Colors___________________________ 3
Wall Thickness__________________ .038”
Tensile Strength (Yarn)_____________ 10
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data__________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max____________________ 56
ASTM E-662
Outgassing____________________ Med
Oxygen Index____________________ 21
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
很抱歉,暂时无法提供与“HWN0.38BK100”相匹配的价格&库存,您可以联系我们找货
