ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
B
raided From .012”
Nylon 6-6 Polyamide
Monofilament Yarns
R
esists Gasoline And
Engine Chemicals
E
conomical And Easy
To Install
E
xpands Up To 150%
C
ut And Abrasion Resistant
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
5/8”
3/4”
1”
1 1/4”
1 1/2”
2”
NYN0.13BK
NYN0.25BK
NYN0.38BK
NYN0.50BK
NYN0.63BK
NYN0.75BK
NYN1.00BK
NYN1.25BK
NYN1.50BK
NYN2.00BK
3/32”
1/8”
1/4”
3/8”
7/16”
1/2”
5/8”
3/4”
1”
1 1/2”
1/4”
3/8”
7/16”
3/4”
1”
1 1/4”
1 3/8”
1 1/2”
2”
3”
1,000’
1,000’
500’
500’
500’
250’
250’
250’
200’
200’
225’
200’
125’
100’
100’
75’
50’
50’
40’
50’
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
0.22
0.31
0.72
1.03
1.12
1.47
1.60
1.78
2.55
2.26
When The Spec Says Nylon And Only
Nylon Will Do
NY is commonly used in the automotive industry
to protect hoses and wire harnesses from
excessive wear. NY’s tough characteristics can
increase hose life up to 300%. This lengthened
life span is recognized in terms of reduced
maintenance, a professional, attractive
and durable appearance and greater
customer satisfaction. With the additional
protection that NY provides, it pays for
itself throughout the life of your product.
Cut Cleanly
Hot Knife
Grade
NYN
NY is braided from .012” nylon 6-6
Polyamide monofilament. The tight braid
construction covers fully and provides excellent
surface abrasion resistance for assemblies
exposed to excessive wear. The smooth nylon
fibers and tight construction also reduce abrasion
damage caused by hoses and harnesses rubbing
against the inside wall of the sleeving.
Monofilament Diameter
.012”
NY resists all common automotive chemicals and
UV damage. It won’t rot or retain moisture.
Material
Nylon 6-6 Polyamide
Drawing Number
TF001NY-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Nylon Mono’s qualities of toughness and sound
suppression make it the choice of auto
manufacturers for protecting and managing
cables routed through door and body cavities.
Colors Available:
Black (BK)
SPECIALTY
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
ABRASION
493°F (256°C)
Maximum Continuous
Mil-I-23053
High
302°F (150°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
72°F
Humidity
48%
Several Strands Broken
400 Test Cycles
Several Small Holes
Worn Through,
Material Destroyed
1,200 Test Cycles
Pre-Test Weight
4,637.0 mg
Post-Test Weight
4,030.3 mg
Test End Loss Of Mass
Point Of Destruction
606.7 mg
CHEMICAL
RESISTANCE
1=No Effect
4=More Affected
2=Little Effect 5=Severely Affected
3=Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 5
Strong Oxidants___________________ 5
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 3
Fungus ASTM G-21_________________ 2
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-49°F (-45°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .012”
ASTM D-204
Recommended Cutting_____ Hot Knife
Colors___________________________ 1
Wall Thickness___________________ .03”
Tensile Strength (Yarn)___________ 10.5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_____ 1.14
Moisture Absorption_____________2.5
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML__________________________1.10
CVCM_________________________ .01
WVR___________________________ .69
Outgassing___________________ High
Oxygen Index____________________ 22
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
很抱歉,暂时无法提供与“NYN0.50BK100”相匹配的价格&库存,您可以联系我们找货
