FWF0.50TB25
FWF0.50TB25
    TECHFLEX
FWF0.50TB25 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups V  W-1, Mil-202 Approved E  conomical And Easy To Install C  ut And Abrasion Resistant R  esists Gasoline And Engine Chemicals Nominal Size Part # 1/2” 3/4” 1 1/4” 2” 2 1/2” FWF0.50TB FWF0.75TB FWF1.25TB FWF2.00TB FXF2.50TB Hook & Recommended Loop Width Application Diameter 1/4” 5/8” 5/8” 5/8” 5/8” 0.50” 0.50” 1.00” 1.25” - Bulk Spool Shop Spool Available Colors Lbs/ 100’ 100’ 100’ 100’ 100’ 100’ 20’ 15’ 12’ 10’ 10’ TB TB TB TB TB 1.30 1.80 2.30 3.20 3.75 H  ook And Loop Closure For Easy And Repeatable Access Easy On, Easy Off Access Will Not Support Combustion Flame Retardant Flexo Wrap (FWF) provides the same hook and loop wire management flexibility as our standard Flexo Wrap along with the added safety feature of an organic flame inhibitor to provide an additional level of security. FWF is a safe, economical solution for a wide range of cable management applications where moderate levels of flame protection are needed. Cut Cleanly Hot Knife Material Polyethylene Terepthalate Colors Available: TB = Black with White Tracer Grade FWF Monofilament Diameter .010” Drawing Number TF001FWFR-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 FLEXO WRAP FR is designed for quick and easy management of wire, cable and hose assemblies. Just separate the hook and loop fasteners along the edge of the material... and slip the entire length of FW around or under your harness or component assembly. The wide expandability range allows FW to easily fit around... odd-shaped connectors and gently constrict around the diameter of your wires. When the FW is in place, simply seal the hook and loop along the edges. VW-1 ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium Rating________________________ VW-1 Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 70°F Humidity 63% Slight Scuffing And One Broken Filament 300 Test Cycles Wear Continues Evenly Approximately One Dozen Filaments Broken 500 Test Cycles Material Destroyed 900 Test Cycles Pre-Test Weight 3,772.7 mg Post-Test Weight 3,391.1 mg Test End Loss Of Mass Point Of Destruction 381.6 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 2 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None 482°F (250°C) Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter________ .010” ASTM D-204 Flammability Rating____________ VW-1 FMVSS-302 Approved Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness_________________ .025” Tensile Strength (Yarn)_____________ 5 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .04 WVR___________________________ .06 Smoke D-Max__________________ 275 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 31 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117
FWF0.50TB25 价格&库存
很抱歉,暂时无法提供与“FWF0.50TB25”相匹配的价格&库存,您可以联系我们找货
