ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
C
omplies to HL1 & HL2
According to the Railway
Standard DIN EN 45545-2
VW-1, FAR 25
E
asy, Cost And Labor
Effective Wraparound
Installation
M
ore Flexible Than Spiral
Wrap Of Split Convoluted
Tubing
25% Edge Overlap
Resists Chemicals & Solvents
Nominal
Size
Part
Wall
Thickness
Monofilament
Diameter
Bulk
Box
Box
A
Box
B
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
2”
F6F0.13TB
F6F0.25TB
F6F0.38TB
F6F0.50TB
F6F0.75TB
F6F1.00TB
F6F1.25TB
F6F1.50TB
F6F2.00TB
.024”
.025”
.025”
.025”
.025”
.038”
.038”
.038”
.038”
.008”
.010”
.010”
.010”
.010”
.015”
.015”
.015”
.015”
10,000’
3,000’
1,200’
800’
500’
400’
250’
200’
150’
400’
200’
150’
150’
100’
100’
75’
75’
50’
100’
100’
75’
75’
50’
50’
25’
25’
25’
TB
TB
TB
TB
TB
TB
TB
TB
TB
0.47
0.60
1.20
1.40
1.60
2.00
2.40
2.70
3.60
Flexible, Semi-Rigid Split Sleeving
Will Not Support Combustion
Flame spread is a vital safety consideration
in applications as diverse as home built aircraft
wiring and safely managing sound & lighting cables at
clubs, concerts and theaters.
To accommodate these issues, and to
provide unequaled flexibility and access,
we’ve developed this unique sleeving product.
Cut Cleanly
Hot Knife
Material
PET
Colors Available:
Black with White
Tracer (TB)
Self-extinguishing F6F fully complies with UL
standard VW-1. The addition of a flame inhibitor
to our triaxially braided F6 split sleeving
provides the perfect solution to a wide range
of cable management needs.
Easy slip over installation, complete access along the
entire run, economy, durability and UL certified flame
retardant make F6F ideal when the goal is to manage
wires and cables safely and effectively.
Grade
F6F
Monofilament Diameter
.008” - .015”
Drawing Number
TF001F6F-WD
The large overlap allows easy
installation over splices and
incline connectors without
exposing wires and cables.
Nominal Diameter
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
FAR-25
VW-1
DIN EN
45545-2
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ABRASION
High
Rating________________________ VW-1
Maximum Continuous
Mil-I-23053
257°F (125°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
70°F
Humidity
63%
Slight Scuffing Visible
500 Test Cycles
Visible Wear And Five
Broken Filaments
1,200 Test Cycles
Material Destroyed
1,600 Test Cycles
Pre-Test Weight
3,469.8 mg
Post-Test Weight
3,114.0 mg
Test End Loss Of Mass
Point Of Destruction
355.8 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effec
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________ 2
Aliphatic Solvents___________________ 1
Chlorinated Solvents_______________ 3
Weak Bases________________________ 1
Salts _____________________________ 1
Strong Bases_______________________ 2
Salt Water 0-S-1926__________________ 1
Hydraulic Fluid MIL-H-5606___________ 1
Lube Oil MIL-L-7808__________________ 1
De-Icing Fluid MIL-A-8243____________ 1
Strong Acids_______________________3
Strong Oxidants____________________2
Esters/Ketones _____________________ 1
UV Light__________________________ 1
Petroleum_________________________ 1
Fungus ASTM G-21___________________1
Halogen Free____________________ Yes
RoHS____________________________Yes
SVHC__________________________ None
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter____ .008”-.015”
ASTM D-204
Flammability Rating____________ VW-1
FMVSS-302 Approved
Recommended Cutting_____Scissor/HK
Colors__________________________ 1
Wall Thickness_____________ .024”-.038”
Tensile Strength (Yarn___________4-6.5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption %__________ .1-.2
ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML____________________________.19
CVCM_________________________ .04
WVR___________________________ .06
ASTM E-662
Outgassing____________________Med
Oxygen Index___________________ 31
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
446°F (230°C)
很抱歉,暂时无法提供与“F6F0.13TB100”相匹配的价格&库存,您可以联系我们找货
