CXN1.25SV30
CXN1.25SV30
    TECHFLEX
    CHROME XC 1 1/4" SILVER 30'
CXN1.25SV30 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups E  conomical And Easy To Install R  esists Gasoline And Engine Chemicals C  onductive Mylar For Shielding Applications Nominal Size Part # 1/4” 5/16” 1/2” 3/4” 1 1/4” 1 1/2” CXN0.25SV CXN0.31SV CXN0.50SV CXN0.75SV CXN1.25SV CXN1.50SV Expansion Range Min Max Bulk Spool Shop Spool 1/4” 5/16” 1/2” 3/4” 1 1/4” 1 1/2” 5/16” 1/2” 3/4” 1 3/8” 2” 3” 500’ 250’ 250’ 200’ 100’ 100’ 125’ 100’ 80’ 40’ 30’ 25’ Available Colors CP, CP, CP, CP, CP, CP, SV, SV, SV, SV, SV, SV, GL GL GL GL GL GL Lbs/ 100’ 0.25 0.36 0.52 0.83 1.25 1.50 I deal For Exposed Applications C  ut And Abrasion Resistant Impressive High Performance Braided Metal Looks No installation hassles. No surface abrasion. No ridiculous expense. Just the look of polished braided steel. Cut Cleanly Hot Knife Material Mylar Grade CXN Monofilament Diameter .005” Colors Available: Copper (CP), Silver (SV) & Gold (GL). These heavy duty metalized mylar sleeves are ideal for dressing up any application with the look of braided stainless steel. The standard CH has a more open look, with transparent PET braided together with the metallic strands to create a slight glimmer when light strikes it and to allow the color of the application to come through for a special effect. Our new X-tra coverage product, Chrome XC, provides fuller coverage with no transparent elements in the braided construction and results in a smooth, continuous metallic shine on any application. Application possibilities include installing clear heatshrink tubing over hoses covered with Chrome for a unique effect. Drawing Number TF001CXN-WD Application possibilities include installing clear heatshrink tubing over hoses covered with Chrome for a unique effect. Colors Available: www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Copper (CP), Silver (SV), Gold (GL). Mylar® is a registered trademark of DuPont Corporation. HALOGEN FREE SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION ASTM D-2117 482°F (250°C) Medium Mil-I-23053 257°F (125°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 70°F Humidity 50% Scuffing And A Few Chrome Strands Broken 20 Test Cycles Wear Pattern Continues 400 Test Cycles Strands Beginning To Break Down Rapidly 600 Test Cycles Braid Worn Through In Both Directions Material Destroyed 700 Test Cycles Pre-Test Weight 2,906 mg Post-Test Weight 2,783.3 mg Test End Loss Of Mass Point Of Destruction CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 3 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter________ .005” ASTM D-204 Recommended Cutting______Hot Knife Colors__________________________ 3 Wall Thickness_________________ .013” Specific Gravity ASTM D-792_______ 1.3 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .14 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 122.7 mg © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Maximum Continuous Abrasion Resistance
CXN1.25SV30
物料型号:CXN0.25、CXN0.31、CXN0.50、CXN0.75、CXN1.25、CXN1.50
器件简介:FLEXO® CHROME XC 是一种高性能的金属外观导电聚酯薄膜,用于屏蔽应用。
它具有类似于抛光编织钢的外观,并且提供了更完整的覆盖,没有编织构造中的透明元素。
这种材料可以安装在任何应用上,以实现平滑、连续的金属光泽效果。
引脚分配:无引脚,为编织金属外观聚酯薄膜。
参数特性: - 壁厚:0.013英寸 - 单丝直径:0.005英寸 - 拉伸强度:未提供 - 特定重力:1.3 - 湿度吸收率:0.2% - 熔点:482°F/250°C - 最大连续工作温度:257°F/125°C - 最小连续工作温度:-94°F/-70°C
功能详解: - 提供与抛光编织钢相似的外观 - 可应用于屏蔽应用 - 不同尺寸的最小扩张和最大扩张值 - 可提供多种颜色
应用信息: - 可以安装在软管上,然后覆盖以聚四氟乙烯热缩管以获得独特效果
封装信息: - 提供卷装和散装两种包装方式 - 有铜色(CP)、银色(SV)、金色(GL)三种颜色可供选择
此外,该产品通过了多种化学耐性测试,包括芳香族溶剂、氯化溶剂、弱碱、盐、强碱、盐水、液压油、润滑油、除冰液、强酸、强氧化剂、酯/酮、紫外线、石油、真菌等。
并且是无卤素的,符合RoHS标准,不含SVHC物质。
CXN1.25SV30 价格&库存
很抱歉,暂时无法提供与“CXN1.25SV30”相匹配的价格&库存,您可以联系我们找货
