ADVANCED ENGINEERING
HEAVY DUTY
Technical Data Sheet
Put-Ups
F
ull Coverage
E
xtreme Abrasion And
Cut Resistance
R
esists Gasoline, UV,
Solvents, Salt Water
And Chemicals
B
raided From 20 mil
Nylon Monofilament
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/4”
1/2”
3/4”
1”
1 1/4”
1 3/4”
2 1/4”
SDN0.25BK
SDN0.50BK
SDN0.75BK
SDN1.00BK
SDN1.25BK
SDN1.75BK
SDN2.25BK
1/4”
1/2”
3/4”
1”
1 1/4”
1 3/4”
2 1/1”
1/2”
1”
1 1/4”
1 1/2”
2”
2 3/4”
3”
500’
250’
250’
250’
250’
100’
100’
100’
100’
50’
50’
50’
25’
25’
Black
Black
Black
Black
Black
Black
Black
1.05
1.85
2.30
2.75
3.00
4.00
5.30
C
ustom Lengths Available
H
alogen Free
Heavy Duty Construction For High
Abrasion Protection, Light Weight &
Flexible For Easy Installation
SD is braided from .020” nylon 6-6
polyamide monofilament. Heavy duty and
flexible, this sleeving is extremely versatile.
Excellent durability makes SD ideal for a wide
range of industrial applications, and other jobs
where high abrasion protection is needed.
Cut Cleanly
Hot Knife
Super Duty will outperform the competition’s
dual monofilament sleeving. SD is also more
economical and easy to use, cutting cleanly with
a hot knife leaving a neat, sealed end.
Material
Nylon 6-6 Monofilament
Grade
SDN
Monofilament Diameter
.020”
Drawing Number
TF001SDN-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
SD protects hydraulic hoses from
abrasion, flying debris and UV damage
without affecting flexibility or trapping
moisture like other abrasion covers.
Colors Available:
Black (BK).
HEAVY
DUTY ENGINEERING
ADVANCED
Melt Point
ASTM D-2117
ABRASION
493°F (256°C)
Maximum Continuous
302°F (150°C)
Very High
Abrasion Test Machine
Minimum Continuous
-49°F (-45°C)
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
72°F
Humidity
48%
Material Destroyed
2,500 Test Cycles
Pre-Test Weight
6,878.6 mg
Post-Test Weight
6,527.2 mg
Test End Loss Of Mass
Point Of Destruction
351.4 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 5
Strong Oxidants___________________ 5
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 3
Fungus ASTM G-21_________________ 2
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC______________________________
PHYSICAL
PROPERTIES
Monofilament Diameter________ .020”
ASTM D-204
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness__________________ .05”
Tensile Strength (Yarn)_____________ 9
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.14
Moisture Absorption_____________ 2.5
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595
TML__________________________ 1.10
CVCM_________________________ .01
WVR___________________________ .69
Outgassing___________________ High
Oxygen Index___________________ 22
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Abrasion Resistance
很抱歉,暂时无法提供与“SDN2.25BK25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+670.624921+86.45649
