ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
Nominal
Size
Complies to HL2 According to
the Railway Standard
DIN EN 45545-2
Part
1/8”
FRN0.13
1/4”
FRN0.25
5/16”
FRN0.31
3/8”
FRN0.38
7/16”
FRN0.44
1/2”
FRN0.50
9/16”
FRN0.56
3/4”
FRN0.75
1”
FRN1.00
1 1/4”
FRN1.25
1 1/2”
FRN1.50
1 3/4”
FRN1.75
2”
FRN2.00
2 1/2”
FRN2.50
3”
FRN3.00
3 End Construction
1/4”
FR30.25TB
E
conomical And Easy
To Install
E
xpands Up To 150%
R
esists Gasoline And
Engine Chemicals
C
ut And Abrasion
Resistant
M
il-202, FAR-25, FMVSS 302,
VW-1, FR-1 Approved
Expansion Range
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
3/32”
1/8”
5/32”
3/16”
7/32”
1/4”
5/16”
1/2”
5/8”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
2 1/2”
1/4”
7/16”
15/32”
1/2”
5/8”
3/4”
7/8”
1 1/4”
1 5/8”
1 3/4”
2 1/2”
2 3/4”
3 1/2”
4 1/2”
4 3/4”
1,000’
1,000’
500’
500’
500’
500’
500’
250’
250’
250’
200’
200’
200’
200’
100’
225’
200’
150’
125’
125’
100’
100’
75’
65’
50’
40’
30’
50’
50’
50’
7
7
7
7
7
7
7
7
7
7
7
7
7
7
7
0.16
0.24
0.50
0.57
0.68
0.72
0.81
1.07
1.34
1.60
1.96
2.70
3.30
3.80
4.00
1/8”
3/8”
1,000’
200’
TB, GW, TW
0.39
Colors Available:
Flame Retardant, Economical
Sleeving Solution
BK,TW,GW,TB,YS,OS,SP
Flexo PET Flame Retardant (FR) sleeving
is the perfect choice for electronic and
high tech applications where flame
retardance and durability are primary
concerns. Ease of installation makes FR an
efficient choice for long runs of wire or cable.
Cut Cleanly
Hot Knife
The addition of an organic combustion inhibitor
to our standard polyethylene terephthalate gives
FR an Underwriters Lab and CSA flame resistance rating
of VW-1.
Material
Polyethylene Terephthalate
Grade
FRN
FR meets or exceeds automotive and aircraft
engineering standards for flammability
and flame retardance.
Colors Available:
Monofilament Diameter
.010”
Drawing Number
TF001FR-WD
Black (BK), White with Black Tracer (TW), Gray with White Tracer(GW),
Black with White Tracer (TB), Black with Yellow Tracer (YS),
Black with Orange Tracer (OS), Black with Red Tracer (SP).
www.techflex.com
800.323.5140 • 973.300.9242 • fax: 973.300.9409
104 Demarest Road • Sparta, NJ 07871
FAR-25
VW-1
DIN EN
45545-2
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
Melt Point
ABRASION
Medium
Rating________________________ VW-1
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
70%
Minor Scuffing Is Visible
100 Test Cycles
Several Broken Strands
And Small Hole
Developing
500 Test Cycles
Material Destroyed
700 Test Cycles
Pre-Test Weight
4124.0 mg
Post-Test Weight
3884.7 mg
Test End Loss Of Mass
Point Of Destruction
239.3 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 2
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .010”
ASTM D-204
Flammability Rating____________ VW-1
FMVSS-302 Approved
Recommended Cutting______Hot Knife
Colors__________________________ 7
Wall Thickness_________________ .025”
Tensile Strength (Yarn)_____________ 5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption%___________ .1-.2
ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .04
WVR___________________________ .06
Smoke D-Max__________________ 275
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 31
ASTM D-2863
© 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
01-07
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
很抱歉,暂时无法提供与“FRN1.75TB30”相匹配的价格&库存,您可以联系我们找货
