FRN1.50TB40
FRN1.50TB40
    TECHFLEX
    TRACER 1 1/2" BLACK W/WHITE 40'
FRN1.50TB40 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups Nominal Size Complies to HL2 According to the Railway Standard DIN EN 45545-2 Part # 1/8” FRN0.13 1/4” FRN0.25 5/16” FRN0.31 3/8” FRN0.38 7/16” FRN0.44 1/2” FRN0.50 9/16” FRN0.56 3/4” FRN0.75 1” FRN1.00 1 1/4” FRN1.25 1 1/2” FRN1.50 1 3/4” FRN1.75 2” FRN2.00 2 1/2” FRN2.50 3” FRN3.00 3 End Construction 1/4” FR30.25TB E  conomical And Easy To Install E  xpands Up To 150% R  esists Gasoline And Engine Chemicals C  ut And Abrasion Resistant M  il-202, FAR-25, FMVSS 302, VW-1, FR-1 Approved Expansion Range Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 3/32” 1/8” 5/32” 3/16” 7/32” 1/4” 5/16” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 2 1/2” 1/4” 7/16” 15/32” 1/2” 5/8” 3/4” 7/8” 1 1/4” 1 5/8” 1 3/4” 2 1/2” 2 3/4” 3 1/2” 4 1/2” 4 3/4” 1,000’ 1,000’ 500’ 500’ 500’ 500’ 500’ 250’ 250’ 250’ 200’ 200’ 200’ 200’ 100’ 225’ 200’ 150’ 125’ 125’ 100’ 100’ 75’ 65’ 50’ 40’ 30’ 50’ 50’ 50’ 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 0.16 0.24 0.50 0.57 0.68 0.72 0.81 1.07 1.34 1.60 1.96 2.70 3.30 3.80 4.00 1/8” 3/8” 1,000’ 200’ TB, GW, TW 0.39 Colors Available: Flame Retardant, Economical Sleeving Solution BK,TW,GW,TB,YS,OS,SP Flexo PET Flame Retardant (FR) sleeving is the perfect choice for electronic and high tech applications where flame retardance and durability are primary concerns. Ease of installation makes FR an efficient choice for long runs of wire or cable. Cut Cleanly Hot Knife The addition of an organic combustion inhibitor to our standard polyethylene terephthalate gives FR an Underwriters Lab and CSA flame resistance rating of VW-1. Material Polyethylene Terephthalate Grade FRN FR meets or exceeds automotive and aircraft engineering standards for flammability and flame retardance. Colors Available: Monofilament Diameter .010” Drawing Number TF001FR-WD Black (BK), White with Black Tracer (TW), Gray with White Tracer(GW), Black with White Tracer (TB), Black with Yellow Tracer (YS), Black with Orange Tracer (OS), Black with Red Tracer (SP). www.techflex.com 800.323.5140 • 973.300.9242 • fax: 973.300.9409 104 Demarest Road • Sparta, NJ 07871 FAR-25 VW-1 DIN EN 45545-2 ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium Rating________________________ VW-1 Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 70% Minor Scuffing Is Visible 100 Test Cycles Several Broken Strands And Small Hole Developing 500 Test Cycles Material Destroyed 700 Test Cycles Pre-Test Weight 4124.0 mg Post-Test Weight 3884.7 mg Test End Loss Of Mass Point Of Destruction 239.3 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 2 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter________ .010” ASTM D-204 Flammability Rating____________ VW-1 FMVSS-302 Approved Recommended Cutting______Hot Knife Colors__________________________ 7 Wall Thickness_________________ .025” Tensile Strength (Yarn)_____________ 5 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption%___________ .1-.2 ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .04 WVR___________________________ .06 Smoke D-Max__________________ 275 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 31 ASTM D-2863 © 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 01-07 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 482°F (250°C)
FRN1.50TB40 价格&库存
很抱歉,暂时无法提供与“FRN1.50TB40”相匹配的价格&库存,您可以联系我们找货
FRN1.50TB40
  • 1+528.349541+68.43975
