HWN1.50BK50
HWN1.50BK50
    TECHFLEX
HWN1.50BK50 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups E  xtreme Abrasion And Cut Resistance R  esists Gasoline, UV, Solvents, Salt Water And Chemicals B  raided From .15 mil PET Monofilament Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 3/8” 5/8” 1” 1 1/2” 2” 3” 4” HWN0.13BK HWN0.38 HWN0.63 HWN1.00 HWN1.50 HWN2.00 HWN3.00 HWN4.00 1/16” 3/16” 5/16” 1/2” 3/4” 1 1/2” 2” 2 1/2” 3/16” 3/4” 7/8” 1 1/2” 2” 3” 4” 5 1/2” 500’ 500’ 250’ 250’ 250’ 200’ 100’ 100’ 125’ 100’ 75’ 50’ 50’ 50’ 50’ 50’ BK 3 3 3 3 3 3 3 0.27 0.82 1.10 1.60 2.50 3.40 4.20 4.20 50% Thicker For The Really Abrasive Jobs When your application calls for more protection than our 10 mil products provide, our 15 mil HW is the ideal solution. HW is commonly used in industrial and marine applications where extreme abrasion protection is critical. The durability of HW makes it ideal for protecting hoses and cables that have to withstand constant contact with rough and abrasive surfaces. Cut Cleanly Hot Knife HW is the perfect solution for use on chains and cables to protect painted or laminated surfaces from scuffing and wear. Material Polyethylene Terephthalate HW protects trailer hitch harnesses from abrasion, flying debris and UV damage without affecting flexibility or trapping moisture like convoluted tubing. Grade HWN Monofilament Diameter .015” Colors Available: Drawing Number TF001HWN-WD Clear (CL), Carbon (CB), and Black (BK). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: 3 = BK, CL, and CB. HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium Rating______________________UL94VO Maximum Continuous Mil-I-23053 257°F (125°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 72% Two Broken Strands 200 Test Cycles Braid Worn Through In One Direction, In Several Places 700 Test Cycles Material Destroyed Braid Worn Through In Both Directions 950 Test Cycles Pre-Test Weight 5,262.7 mg Post-Test Weight 4,979.9 mg Test End Loss Of Mass Point Of Destruction 239.3 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter_________ .015” ASTM D-204 Flammability Rating_____________UL94 Recommended Cutting______ Hot Knife Colors___________________________ 3 Wall Thickness__________________ .038” Tensile Strength (Yarn)_____________ 10 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data__________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max____________________ 56 ASTM E-662 Outgassing____________________ Med Oxygen Index____________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 482°F (250°C)
HWN1.50BK50 价格&库存
很抱歉,暂时无法提供与“HWN1.50BK50”相匹配的价格&库存,您可以联系我们找货
HWN1.50BK50
    • 1+633.140341+81.91361
