ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
M
anages And Protects
Cable Bundles
I ncreased Safety In
Foot Traffic Areas
E
conomical And Easy
To Install
E
xpands Up To 150%
C
ut And Abrasion
Resistant
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/4”
3/8”
1/2”
5/8”
3/4”
1 1/4”
1 1/2”
2”
NSN0.25
NSN0.38
NSN0.50
NSN0.63
NSN0.75
NSN1.25
NSN1.50
NSN2.00
1/8”
3/16”
1/4”
3/8”
1/2”
3/4”
1”
1 1/2”
7/16”
1/2”
3/4”
1”
1 1/4”
1 3/4”
2”
3 1/2”
1,000’
500’
500’
500’
250’
200’
200’
200’
200’
125’
100’
75’
70’
50’
40’
50’
NY, BK, SS
NY, BK, SS
NY, BK, SS
NY, BK, SS
NY & BK
NY, BK, SS
NY, BK, SS
NY & BK
0.44
0.57
0.89
1.04
1.25
1.96
2.25
2.75
Increased Friction On Smooth Surfaces
Minimizes Slipping And Accidents
FLEXO® NON-SKID (NS) is a unique combination
of our standard PET material braided together
with a matching thread of a high-friction polymer.
NS is engineered primarily for wire and cable
management in smooth floor, high traffic
environments such as broadcast studios
where someone might inadvertently step
on a cable snake and slip.
Cut Cleanly
Hot Knife
Material
Polyethylene Terepthalate
Grade
NSN
As long as there’s no excessive pressure
on cables protected with NS, the entire snake
glides easily and quietly along the floor.
When local pressure is applied, such as someone
stepping on the cable, the high friction material
comes in contact with the floor and reduces the
possibility of the cable sliding out from underfoot.
NS is substantially less “slippery” than our regular PET,
yet provides the same level of flexibility and protection
from cable wear and abrasion.
Monofilament Diameter
.028”
Non-Skid is ideal for smooth floor areas
such as photo, film and TV studios where
cable snakes, high foot traffic and low light
combine to create a slipping hazard.
Drawing Number
TF001NS-WD
Colors Available:
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Neon Yellow (NY), Black (BK) and Safety Stripe (SS).
Colors Available:
BK, NY, and SS
SPECIALTY
ADVANCED
ENGINEERING
ABRASION
Melt Point
ASTM D-2117
Medium
Mil-I-23053
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
71°F
Humidity
53%
Braid (1 Carrier) Broken
In One Direction
350 Test Cycles
Material Destroyed Braid Broken In Both
Directions
650 Test Cycles
Pre-Test Weight
4,360.5 mg
Post-Test Weight
4,147.0 mg
Test End Loss Of Mass
Point Of Destruction
213.5 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
175°F (79°C)
Minimum Continuous
-40°F (-40°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .028”
ASTM D-204
Recommended Cutting______Hot Knife
Colors__________________________ 3
Wall Thickness__________________ .07”
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
260°F (126°C)
Maximum Continuous
Abrasion Resistance
很抱歉,暂时无法提供与“NSN0.75NY70”相匹配的价格&库存,您可以联系我们找货
