GWN1.38BK25
GWN1.38BK25
    TECHFLEX
GWN1.38BK25 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups W  rappable Design For Easy Installation And removal Nominal Size Part # Flat Width 3/4” GWN0.75BK 2 15/16” 1” GWN1.00BK 4 7/16” 1 3/8” GWN1.38BK 5 5/16” Extra Flexible Construction 3/4” GWX0.75BK 3 1/8” M  ore Excellent Protection Against Cut-Through, Abrasion And Impact C  losure Maintains Low Profile For Flat Cables & Harnesses Monofilament Diameter Bulk Box Shop Spool Available Colors Lbs/ 100’ .010” .010” .010” 50’ 50’ 50’ 25’ 25’ 25’ Black Black Black 2.00 3.00 4.00 .010” 50’ 25’ 25’ 4.00 M  elt Temp. 482°F One Size - Multiple Possibilities Adjustable Diameter Sleeve with Easy On, Easy Off Access GRIPWRAP® (GWN) is a lightweight, abrasion resistant sleeving with a unique hook sealing system that eliminates spot taping and does not require an open end for installation. The sleeving permits easy access for inspection, rework or replacement of components. GripWrap® provides cut-through and abrasion protection, and is easily applied to areas restricted by breakouts and large end fittings. Can be used to bundle wire harnesses, and also can be used to substitute molded channels. Cut Cleanly Hot Knife The unique GripWrap® system provides a variety of sealing and mounting options to accommodate any harnessing or cable management application. Material Polyethylene Terephthalate Colors Available: Black (BK) Grade GWN Monofilament Diameter .010” Drawing Number TF001FWPT-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION High Rating______________________UL94VO 482°F (250°C) Maximum Continuous Mil-I-23053 257°F (125°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter________ .010” ASTM D-204 Flammability Rating____________ UL94 Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness_________________ .025” Tensile Strength (Yarn)____________ 7.5 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2022 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 12-06 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117
GWN1.38BK25 价格&库存
很抱歉,暂时无法提供与“GWN1.38BK25”相匹配的价格&库存,您可以联系我们找货
