F6Q0.25BK100
F6Q0.25BK100
    TECHFLEX
    F6 QUIET SLEEVING 1/4" BLK 100'
F6Q0.25BK100 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups R  etro Look For Audio Cables S  oft, Classic Cotton Loom Feel C  ut And Abrasion Resistant C  uts Cleanly with Hot Knife H  alogen Free Nominal Size Part # Wall Thickness ±0.005” Bulk Spool Box A Box B Available Colors Lbs/ 100’ 1/4” 3/8” 1/2” 3/4” 1 1/4” F6Q0.25BK F6Q0.38BK F6Q0.50BK F6Q0.75BK F6Q1.25BK 0.04” 0.04” 0.04” 0.04” 0.04” 2,000’ 1,000’ 800’ 500’ 250’ 200’ 150’ 150’ 100’ 75’ 100’ 75’ 75’ 50’ 25’ Black Black Black Black Black 1.00 1.80 2.00 3.00 4.00 Nostalgic Look And Feel! Modern Day Performance! Flexo® F6 Quiet is specially engineered to reduce the noise associated with wire harnesses or cables installed in hard to reach areas such as door panels or dashboards. The special construction suppresses noise from loose harnesses moving against body or dash panels. Cut Cleanly Hot Knife F6 Quiet also has a soft and flexible feel, reminiscent of old style cotton loom, making it the perfect product for restoration projects. Material Polyethylene Terephthalate Grade F6Q Wall Thickness .04” Drawing Number TF001F6Q-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Noise suppression wrap for harnesses and cable in cavities and dashboard installations. Colors Available: Black (BK) SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Highs Rating_______________________ *UL94 *UL 94 V-O Raw Material Maximum Continuous Mil-I-23053 257°F (125°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 83°F Humidity 78% Most Soft Material Worn Away In Test Area But PET Braid Is Intact 1,000 Test Cycles Braid Worn Through In Both Directions - Material Destroyed 1,500 Test Cycles Pre-Test Weight 4,911.80 mg Post-Test Weight 3,838.50 mg Test End Loss Of Mass Point Of Destruction 1,073.30 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -22°F (-30°C) PHYSICAL PROPERTIES Monofilament Diameter___ .008”-.015” ASTM D-204 Flammability Rating___________ *UL94 *UL 94 V-O Raw Material Recommended Cutting____ Scissor/HK Colors__________________________ 1 Wall Thickness__________________ .04” Tensile Strength (Yarn)____________ 7.5 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 446°F (230°C)
F6Q0.25BK100 价格&库存
很抱歉,暂时无法提供与“F6Q0.25BK100”相匹配的价格&库存,您可以联系我们找货
