ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
L ightweight
Nominal
Size
S
elf-Wrapping
D
urable Woven Design
M
aintains Wires in
Flat Shape
L ow Profile
Part
Width
Bulk
Spool
Shop
Spool
1”
F6Z1.00BK
30mm
50'
25'
Black (BK)
3.26
F6Z1.50BK
F6Z1.75BK
F6Z2.25BK
40mm
50mm
60mm
50'
50'
50'
25'
25'
25'
Black (BK)
Black (BK)
Black (BK)
4.34
5.42
6.51
Built on the same design as out Flexo® F6 and F6
Woven, Flexo® F6 Flat is a self-wrappable sleeve used
to bundle and protect wire harnesses and cable assemblies in areas where space constraints restrict the use of
traditional sleeving.
Lightweight and durable, it maintains its flexibility for
conforming to irregular shapes and bends during installation.
Material
Polyethylene terephthalate
Grade
F6Z
Woven from monofilament and multifilament polyester
yarn, Flexo® F6 Flat provides noise suppression and a
high level of mechanical abrasion protection making it
the perfect for use in automotive applications.
The low-profile design is great for channeling and protecting wires that run under the carpet or in the headliner of automobiles.
Great For Channeling and Protecting Wires
That Run Under The Carpet or in the Headliner
of Automobiles.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Lbs/
100’
1 1/2”
1 3/4”
2 1/4”
Self-Wrapping Flat Design
Cut Cleanly
Scissors
Available
Colors
Colors Available:
Black (BK)
SPECIALTY
ADVANCED
ENGINEERING
ABRASION
Abrasion Resistance
Melt Point
Very High
ASTM D-2117
493°F (256°C)
Abrasion Test Machine
Maximum Continuous
Taber 5150
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
72°F
Humidity
74%
Slight Fraying On
Multifilament
- PET Unbroken
100 Test Cycles
Holes Worn Through
Multifilament
- PET Unbroken
800 Test Cycles
Holes Worn Through
Multifilament
- PET Unbroken
1,600 Test Cycles
Material Destroyed
2,800 Test Cycles
Pre-Test Weight
11,781.6 mg
Post-Test Weight
9,279.1 mg
Test End Loss Of Mass
Point Of Destruction
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
Minimum Continuous
-49°F (-45°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .015”
ASTM D-204
Recommended Cutting_____ Hot-Knife
Colors___________________________ 1
Wall Thickness__________________ .038”
Specific Gravity ASTM D-79_______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max____________________ 56
Outgassing____________________ Med
Oxygen Index____________________ 21
2,502.5 mg
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
302°F (150°C)
Abrasion Test Wheel
很抱歉,暂时无法提供与“F6Z2.25BK25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+841.060381+108.70639
