ADVANCED ENGINEERING
Technical Data Sheet
Nom
inal
Diam
eter
Hoo
k&
Widt Loop
h
Complies to HL2 According to
the Railway Standard
DIN EN 45545-2
U
L and VW-1
P
asses Smoke Density Test
ASTM E-662
P
asses Surface Flammability
Test ASTM E-162
P
asses Smoke Toxicity Test
SMP 800-C
M
elt Temp. 482°F
Cuts Cleanly
Hot Knife
Material
PET Polyethylene Terephthalate
Grade
F6V
Put-Ups
Standard Put-Ups
Nominal
Size
Part
Wall
Thickness
Bulk
A
B
Available
Colors
Overlap
*A
Lbs/
100’
3/16”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
F6V0.19TB
F6V0.38TB
F6V0.50TB
F6V0.75TB
F6V1.00TB
F6V1.25TB
F6V1.50TB
.027”
.027”
.027”
.027”
.027”
.027”
.027”
3,000’
2,000’
1,500’
1,000
460’
330’
260’
500’
250’
200’
150’
100’
75’
50’
100’
100’
75’
50’
50’
25’
25’
TB
TB
TB
TB
TB
TB
TB
51%
41%
35%
28%
26%
25%
23%
0.8
1.2
1.6
2.5
3.2
3.7
4.8
Woven, Flame Retardant Split Tubular
Harness Wrap
F6 Woven Wrap FR (F6V) is a VW-1 Rated version our
industry recognized F6 Woven Wrap, with the added
advantage of a flame inhibitor to provide an extra level
of safety. It utilizes many of the same
characteristics as our original F6 split braided
sleeving including the easy wrap around design
and the extra overlap to ensure complete protection
of important electronic communication and power
systems. The new woven construction provides superior
elastic flexibility with unbeatable coverage over any
harness assembly. Through a unique process, the blend
of monofilament and multifilament polyester fibers are
formed into a sleeving with memory that causes the
sleeve to self close, and also snap back when opened.
The combination of flame retardance, ease of
installation, and complete coverage makes F6 Woven FR
an ideal solution for many commercial and aerospace
applications.
Colors Available:
Black w/White Tracer
(TB)
The Right Overlap
For Your Harness
Hook & Loop
Width
Filament Diameter
.010” Monofilament Polyester
1200 Denier Multifilament
Drawing Number
TF001FWPT-WD
*A
Nominal Diameter
The engineered overlap allows ideal
flexibility without exposing wires and cables.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
VW-1
DIN EN
45545-2
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
eter
Diam
nal
Loop
k&
Hoo idth
W
i
Nom
Melt Point
ABRASION
Medium
Rating ________________________ VW-1
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 2
UV Light _________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________Yes
RoHS___________________________Yes
SVHC_________________________ None
482°F (250°C)
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
PHYSICAL
PROPERTIES
Filament Diameter:
Monofilament Polyester_____ .010”
Multifilament________ 1200 Denier
Flammability Rating: ___________VW-1
Self Extinguishing, Type A
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness_________________ .027”
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML (%)_______________________ .19
CVCM (%)______________________ .00
WVR (%)_______________________ .06
Smoke D-Max__________________ 275
Outgassing___________________ Med
Oxygen Index___________________ 31
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
很抱歉,暂时无法提供与“F6V0.38TB100”相匹配的价格&库存,您可以联系我们找货
