F6F1.25TB25
F6F1.25TB25
    TECHFLEX
    FLAME RETARDANT 1 1/4" BLACK 25'
F6F1.25TB25 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups C  omplies to HL1 & HL2 According to the Railway Standard DIN EN 45545-2 VW-1, FAR 25 E  asy, Cost And Labor Effective Wraparound Installation M  ore Flexible Than Spiral Wrap Of Split Convoluted Tubing 25% Edge Overlap Resists Chemicals & Solvents Nominal Size Part # Wall Thickness Monofilament Diameter Bulk Box Box A Box B Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” 2” F6F0.13TB F6F0.25TB F6F0.38TB F6F0.50TB F6F0.75TB F6F1.00TB F6F1.25TB F6F1.50TB F6F2.00TB .024” .025” .025” .025” .025” .038” .038” .038” .038” .008” .010” .010” .010” .010” .015” .015” .015” .015” 10,000’ 3,000’ 1,200’ 800’ 500’ 400’ 250’ 200’ 150’ 400’ 200’ 150’ 150’ 100’ 100’ 75’ 75’ 50’ 100’ 100’ 75’ 75’ 50’ 50’ 25’ 25’ 25’ TB TB TB TB TB TB TB TB TB 0.47 0.60 1.20 1.40 1.60 2.00 2.40 2.70 3.60 Flexible, Semi-Rigid Split Sleeving Will Not Support Combustion Flame spread is a vital safety consideration in applications as diverse as home built aircraft wiring and safely managing sound & lighting cables at clubs, concerts and theaters. To accommodate these issues, and to provide unequaled flexibility and access, we’ve developed this unique sleeving product. Cut Cleanly Hot Knife Material PET Colors Available: Black with White Tracer (TB) Self-extinguishing F6F fully complies with UL standard VW-1. The addition of a flame inhibitor to our triaxially braided F6 split sleeving provides the perfect solution to a wide range of cable management needs. Easy slip over installation, complete access along the entire run, economy, durability and UL certified flame retardant make F6F ideal when the goal is to manage wires and cables safely and effectively. Grade F6F Monofilament Diameter .008” - .015” Drawing Number TF001F6F-WD The large overlap allows easy installation over splices and incline connectors without exposing wires and cables. Nominal Diameter www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 FAR-25 VW-1 DIN EN 45545-2 ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION High Rating________________________ VW-1 Maximum Continuous Mil-I-23053 257°F (125°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 70°F Humidity 63% Slight Scuffing Visible 500 Test Cycles Visible Wear And Five Broken Filaments 1,200 Test Cycles Material Destroyed 1,600 Test Cycles Pre-Test Weight 3,469.8 mg Post-Test Weight 3,114.0 mg Test End Loss Of Mass Point Of Destruction 355.8 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effec 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________ 2 Aliphatic Solvents___________________ 1 Chlorinated Solvents_______________ 3 Weak Bases________________________ 1 Salts _____________________________ 1 Strong Bases_______________________ 2 Salt Water 0-S-1926__________________ 1 Hydraulic Fluid MIL-H-5606___________ 1 Lube Oil MIL-L-7808__________________ 1 De-Icing Fluid MIL-A-8243____________ 1 Strong Acids_______________________3 Strong Oxidants____________________2 Esters/Ketones _____________________ 1 UV Light__________________________ 1 Petroleum_________________________ 1 Fungus ASTM G-21___________________1 Halogen Free____________________ Yes RoHS____________________________Yes SVHC__________________________ None Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter____ .008”-.015” ASTM D-204 Flammability Rating____________ VW-1 FMVSS-302 Approved Recommended Cutting_____Scissor/HK Colors__________________________ 1 Wall Thickness_____________ .024”-.038” Tensile Strength (Yarn___________4-6.5 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption %__________ .1-.2 ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML____________________________.19 CVCM_________________________ .04 WVR___________________________ .06 ASTM E-662 Outgassing____________________Med Oxygen Index___________________ 31 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 446°F (230°C)
F6F1.25TB25 价格&库存
很抱歉,暂时无法提供与“F6F1.25TB25”相匹配的价格&库存,您可以联系我们找货
F6F1.25TB25
  • 1+865.603821+111.51941
