PTN0.38BR
PTN0.38BR
    TECHFLEX
    PET 3/8" BROWN 500'
PTN0.38BR 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups Nominal Size E  conomical And Easy To Install 1/16” PTN0.06 1/8” PTN0.13 1/4” PTN0.25 5/16” PTN0.31 3/8” PTN0.38 7/16” PTN0.44 1/2” PTN0.50 9/16” PTN0.56 5/8” PTN0.63 3/4” PTN0.75 1” PTN1.00 1 1/4” PTN1.25 1 1/2” PTN1.50 1 3/4” PTN1.75 2” PTN2.00 2 1/2” PTN2.50 3” PTN3.00 3 END CONSTRUCTION 1/4” PT30.25 9 MIL CONSTRUCTION 4” PT94.00BK PET LEAN 3/4” PTL0.75BK 1 1/4” PTL1.25BK R  esists Gasoline, Engine Chemicals And Cleaning Solvents E  xpands Up To 150% C  ut And Abrasion Resistant F  MVSS 302 Approval Cut Cleanly Hot Knife Material Polyethylene Terepthalate Grade PTN Monofilament Diameter .010” Drawing Number TF001PET-WD Part # Expansion Range Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 3/64” 3/32” 1/8” 5/32” 3/16” 7/32” 1/4” 5/16” 3/8” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 2 1/2” 3/32” 1/4” 7/16” 15/32” 1/2” 5/8” 3/4” 7/8” 1” 1 1/4” 1 5/8” 1 3/4” 2 1/8” 2 3/4” 3 1/2” 3 5/8” 4 3/4” 1,000’ 1,000’ 1,000’ 500’ 500’ 500’ 500’ 500’ 500’ 250’ 250’ 250’ 200’ 200’ 200’ 200’ 100’ 250’ 225’ 200’ 150’ 125’ 125’ 100’ 100’ 100’ 75’ 65’ 50’ 40’ 30’ 50’ 50’ 50’ more than 40 BK,CL,NB,RE 0.22 0.20 0.30 0.50 0.57 0.68 0.77 0.81 0.95 1.20 1.34 1.60 1.96 2.45 2.60 3.80 4.00 1/8” 3/8” 1,000’ 200’ 4 0.39 4” 6 1/2” 100’ 50’ BK 3.80 1/2” 3/4” 1 1/4” 1 3/4” 250’ 250’ 75’ 50’ BK BK 1.04 1.19 Colors Available: A Versatile Bundling And Protection Solution See color chart The FLEXO® Original braided from 10 mil polyethylene terepthalate (PET) monofilament yarns. The material has a wide operating temperature range, is resistant to chemical degradation, UV radiation, and abrasion. Used in electronics, automotive, marine and industrial wire harnessing applications where cost efficiency and durability are critical. The unique braided construction and wide expandability allows quick and easy installation over large connectors and long runs. High thermal and chemical resistance and wide color/size selection make FLEXO® Original PET ideal for customizing and protecting the wires, hoses and cables in custom and classic colors. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 FAR-25 GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION High Rating_______________ UL94VO, FAR25, FMVSS-302 Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 77°F Humidity 72% Two Broken Filament 300 Test Cycles Approximately 6 Broken Filaments 500 Test Cycles Material Destroyed - Very Visible Hole In Material 1,150 Test Cycles Pre-Test Weight 4,547.4 mg Post-Test Weight 4,133.9 mg Test End Loss Of Mass Point Of Destruction 413.5 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter_________ .010 ASTM D-204 Flammability Rating____________ UL94 FMVSS-302 Approved Recommended Cutting______Hot Knife Colors________________________ >40 Wall Thickness__________________ .025 Tensile Strength (Yarn)____________ 7.5 ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2021 Techflex®, Inc. - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex®, Inc. is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, Inc., unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex®’s only obligations are those in standard terms of sale for these products and Techfle® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.obroilandmarine.com Abrasion Resistance FLAMMABILITY ASTM D-2117 482°F (250°C) ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet WH White CF Checkered Flag PG Platinum Gray SK Snake BR Brown AQ Aqua RD Red OR Orange YL Yellow GN Green BL Blue PP Purple CL Clear BK Black CB Carbon BE Beige GY Gray DP Dark Purple * NR Neon Red * NP Neon Pink * NY Neon Yellow * NG Neon Green * NB Neon Blue *NO Neon Orange PT Patriot * NX Nitrox * JS Jester * OG Ogre * SH Super Hero SS Safety Stripe GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet C  ustom combination colors manufactured by Techflex T  he possibilities are endless! RE Reggae FG Forest Green BM Black Magic CC Candy Cane AL Alien Alien MO Monochrome Monochrome GW Gray White DS Desert Desert RS Red Spiral UG Uptown Green Green UY Uptown Yellow Yellow UR Uptown Red Red UP Uptown Purple UB Uptown Blue UX Uptown Gold CO Coral HH Hip Hop SB Sherbert TL Twilight RW Rainbow HO Holiday BB Black Beige GD Ground Wire SM Shimmer CK Corn Kernel RC Rainbow Clear RB Rainbow Black www.obroilandmarine.com
PTN0.38BR 价格&库存
很抱歉,暂时无法提供与“PTN0.38BR”相匹配的价格&库存,您可以联系我们找货
