EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
FLAT
Put-Ups
E
conomical And Easy
To Install
C
uts Easily With Scissors
R
eflects Radiant Heat
I nsulates Delicate Wires
And Components
R
esists Gasoline And
Engine Chemicals
Nominal
Size
Part
Wall
Thickness
±0.006”
Bulk
Spool
Shop
Spool
1”
1 1/2”
2”
3”
4”
5”
6”
6 7/8”
TSN1.00SV
TSN1.50SV
TSN2.00SV
TSN3.00SV
TSN4.00SV
TSN5.00SV
TSN6.00SV
TSN6.88SV
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
250’
250’
250’
250’
250’
200’
100’
100’
100’
100’
100’
100’
100’
100’
50’
50’
Available
Colors
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Lbs/
100’
(SV)
(SV)
(SV)
(SV)
(SV)
(SV)
(SV)
(SV)
1.60
2.00
2.75
4.30
5.60
7.60
9.20
10.90
Reflective Aluminized Surface Bonded
To Insulating Fiberglass
THERMASHIELD® creates a buffer between your wires, hoses and cables
and the high temperature environments they are required to perform in.
ThermaShield® is engineered by laminating an aluminum heat shield to a layer
of strong fiberglass insulation. This system provides superior protection from
radiant heat by reflecting it away from sensitive electronics, wiring and hoses.
Cut Cleanly
Scissors
THERMASHIELD® FLAT (TSN) protects surfaces exposed to extreme heat with
TSN. An aluminum laminated fiberglass sheet with a full coating of permanent,
high temperature adhesive, applies directly to any clean surface. Ideal solution
for protecting delicate electronic component boxes mounted close to engines or
other heat sources. When applied, the aluminum laminate reflects heat away and
the insulating fiberglass backing protects the fragile contents from
thermal damage and failure.
Colors Available:
Silver (SV)
Material
Aluminum Laminated Fiberglass
Grade
TSN
Wall Thickness
.025”
reflects heat away and the insulating
contents from thermal damage and failure.
Drawing Number
TF001TS-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
HALOGEN
FREE
FAR-25
EXTREME
TEMPERATURE
FLAT
Melt Point
ASTM D-2117
ABRASION
Very High
Rating______________Non Combustible
Will not burn
Abrasion Test Machine
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
70°F
Humidity
57%
Foil Layer Worn Through
1,000 Test Cycle
Fiberglass Layer Worn
Through - Material
Destroyed
1,300 Test Cycles
Pre-Test Weight
10,804.3 mg
Post-Test Weight
9,918.5 mg
Test End Loss Of Mass
Point Of Destruction
885.8 mg
Mil-I-23053
491°F (255°C)
Minimum Continuous
-76°F (-60°C)
Taber 5150
Abrasion Test Wheel
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
PHYSICAL
PROPERTIES
Flammability Rating__Non Combustible
Recommended Cutting________Scissor
Colors__________________________ 1
Wall Thickness_________________ .025”
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“TSN1.00SV100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1250.557251+161.79297
