ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
R
etro Look For Audio Cables
S
oft, Classic Cotton Loom
Feel
C
ut And Abrasion Resistant
C
uts Cleanly with Hot Knife
H
alogen Free
Nominal
Size
Part
Wall Thickness
±0.005”
Bulk
Spool
Box
A
Box
B
Available
Colors
Lbs/
100’
1/4”
3/8”
1/2”
3/4”
1 1/4”
F6Q0.25BK
F6Q0.38BK
F6Q0.50BK
F6Q0.75BK
F6Q1.25BK
0.04”
0.04”
0.04”
0.04”
0.04”
2,000’
1,000’
800’
500’
250’
200’
150’
150’
100’
75’
100’
75’
75’
50’
25’
Black
Black
Black
Black
Black
1.00
1.80
2.00
3.00
4.00
Nostalgic Look And Feel!
Modern Day Performance!
Flexo® F6 Quiet is specially engineered to reduce
the noise associated with wire harnesses or
cables installed in hard to reach areas such as
door panels or dashboards.
The special construction suppresses noise
from loose harnesses moving against body or
dash panels.
Cut Cleanly
Hot Knife
F6 Quiet also has a soft and flexible feel,
reminiscent of old style cotton loom, making it
the perfect product for restoration projects.
Material
Polyethylene Terephthalate
Grade
F6Q
Wall Thickness
.04”
Drawing Number
TF001F6Q-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Noise suppression wrap for harnesses and cable
in cavities and dashboard installations.
Colors Available:
Black (BK)
SPECIALTY
ADVANCED
ENGINEERING
Melt Point
ABRASION
Highs
Rating_______________________ *UL94
*UL 94 V-O Raw Material
Maximum Continuous
Mil-I-23053
257°F (125°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
83°F
Humidity
78%
Most Soft Material Worn
Away In Test Area But PET
Braid Is Intact
1,000 Test Cycles
Braid Worn Through
In Both Directions
- Material Destroyed
1,500 Test Cycles
Pre-Test Weight
4,911.80 mg
Post-Test Weight
3,838.50 mg
Test End Loss Of Mass
Point Of Destruction
1,073.30 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-22°F (-30°C)
PHYSICAL
PROPERTIES
Monofilament Diameter___ .008”-.015”
ASTM D-204
Flammability Rating___________ *UL94
Recommended Cutting____ Scissor/HK
Colors__________________________ 1
Wall Thickness__________________ .04”
Tensile Strength (Yarn)____________ 7.5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
446°F (230°C)
很抱歉,暂时无法提供与“F6Q0.50BK75”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1036.459741+133.61966
