EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
U
L Recognized
Continuous Filament E-Type
Glass
R
esists Abrasion, Vibration,
And Mechanical Stress
Expansion Range
Nominal
Size
Part
Wall
Thickness
Min.
Max.
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/2”
3/4”
1”
1 1/4”
1 1/2”
FHH0.50NT
FHH0.75NT
FHH1.00NT
FHH1.25NT
FHH1.50NT
0.025”
0.040”
0.032”
0.035”
0.035”
3/8”
5/8”
7/8”
1”
1 1/8”
5/8”
1 5/32”
1 3/8”
1 3/4”
2 1/8”
100’
100’
50’
50’
50’
50’
50’
25’
25’
25’
Natural
Natural
Natural
Natural
Natural
3.50
8.00
7.00
10.50
10.00
E
asy To Install - Cuts With
Scissors
S
tays Flexible In Low Temps
Heavy Wall Fiberglass
Protects To 1,200°F
The heavy wall (1/32”) construction, large
available diameters and high expandability
of Ultra Flex® Pro provides a high level of
protection and ease of installation when used
to insulate pipes and hoses subject to abrasion
and vibration.
Colors Available:
Natural (NT)
Ultra Flex® Pro cuts easily with scissors, and
special heat treated construction minimizes
fraying and dusting during assembly.
Expands Up To 50%
For Easy Installation
Material
Fiberglass
Grade
FHH
Wall Thickness
Refer to Chart
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
“...will withstand extreme heat...
provides the protection needed”
VW-1
EXTREME
TEMPERATURE
Melt Point
ASTM D-2117
ABRASION
Medium
Rating________________________ VW-1
Maximum Continuous
Mil-I-23053
1,202°F (650°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
75°F
Humidity
72%
Individual Fibers Visibly
Broken
150 Test Cycles
Braid Worn Through In
One Direction
500 Test Cycles
Material Destroyed
525 Test Cycles
Pre-Test Weight
*20,831.10 mg
Post-Test Weight
*19,203.20 mg
Test End Loss Of Mass
Point Of Destruction
1,140.51 mg
*Weight Includes
Mounting Card
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________NA
ASTM D-204
Flammability Rating____________ VW-1
Recommended Cutting________Scissor
Colors__________________________ 1
Wall Thickness____________ .025”-.035”
Tensile Strength (Yarn)______________
ASTM D-2256 Lbs
Specific Gravity ASTM D-792____1.0-1.8
Moisture Absorption_____________ .01
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .01
CVCM_________________________ .00
WVR___________________________ .00
Smoke D-Max_____________________
ASTM E-662
Outgassing____________________ Low
Oxygen Index_____________________
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“FHH1.50NT25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+810.153421+104.75945
