SKN2.00BG
SKN2.00BG
    TECHFLEX
    SELFWRAP2"X10'BLUEGREEN
SKN2.00BG 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups D  urable And Reusable Design W  orks Well In Both Film And Video Shoots P  atent Pending Nominal Size Part # Wall Thickness Hook & Loop Standard Spool Put-Ups Spool Length Available Colors Lbs/ 10’ 2” SKN2.00BG .048” 1” 10’ Blue/Green BG 2.25 2 1/2” SKN2.50BG .048" 1" 10' Blue/Green BG 2.80 *Contact your Account Representative for additional sizes. C  overs Wires And Set Pieces C  ut And Abrasion Resistant Keyable Sleeve For Special Effects Professionals Cut Cleanly Scissor Blue/green screen was originally invented as a film technique to separate the actors and composite them over another background. The reason both green and blue are used because they are the least prominent colors in our skin tone. The goal in using a green or a blue screen is to isolate the subject. Following the same concept, Techflex engineers have designed STUDIO KEY WRAP (SK), a reversible, bright blue/green sleeving, which is perfect cover-up for wires on your set. During film editing, you can easily key-out the green and blue colors, so you will be left with just your subject without any background or wires hanging around and set pieces. Studio Key Wrap is made of durable, two sided vinyl, with blue on one side and green on other, and it has hook and loop for quick and easy installation. Our sleeving is thick enough not to let the light pass through it, and also protects your cables against unwanted moisture. Colors Available: Material Vinyl Blue/Green (BG) Grade SKN Wall Thickness .048” www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Whether your studio is set up for green or blue, reversible Key Wrap has you covered. SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet ABRASION www.techflex.com Abrasion Resistance Low Material Destroyed 362 Test Cycles Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ Aliphatic Solvents__________________ Chlorinated Solvents_______________ Weak Bases_______________________ Salts_____________________________ Strong Bases______________________ Salt Water 0-S-1926_________________ Hydraulic Fluid MIL-H-5606__________ Lube Oil MIL-L-7808________________ De-Icing Fluid MIL-A-8243___________ Strong Acids______________________ Strong Oxidants___________________ Esters/Ketones____________________ UV Light_________________________ Petroleum________________________ Fungus ASTM G-21_________________ PHYSICAL PROPERTIES 1 1 1 1 1 2 1 1 1 1 4 4 1 1 2 1 Recommended Cutting________ Scissor Colors__________________ 1 Reversible Wall Thickness_________________ .048” Specific Gravity ASTM D-792_______ NA Moisture Absorption_____________ NA % ASTM D-570 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
SKN2.00BG 价格&库存
很抱歉,暂时无法提供与“SKN2.00BG”相匹配的价格&库存,您可以联系我们找货
