FHH1.00NT
FHH1.00NT
    TECHFLEX
    FIBERGLASS HEAVY WALL 1" 50'
FHH1.00NT 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups U  L Recognized Continuous Filament E-Type Glass R  esists Abrasion, Vibration, And Mechanical Stress Expansion Range Nominal Size Part # Wall Thickness Min. Max. Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/2” 3/4” 1” 1 1/4” 1 1/2” FHH0.50NT FHH0.75NT FHH1.00NT FHH1.25NT FHH1.50NT 0.025” 0.040” 0.032” 0.035” 0.035” 3/8” 5/8” 7/8” 1” 1 1/8” 5/8” 1 5/32” 1 3/8” 1 3/4” 2 1/8” 100’ 100’ 50’ 50’ 50’ 50’ 50’ 25’ 25’ 25’ Natural Natural Natural Natural Natural 3.50 8.00 7.00 10.50 10.00 E  asy To Install - Cuts With Scissors S  tays Flexible In Low Temps Heavy Wall Fiberglass Protects To 1,200°F The heavy wall (1/32”) construction, large available diameters and high expandability of Ultra Flex® Pro provides a high level of protection and ease of installation when used to insulate pipes and hoses subject to abrasion and vibration. Colors Available: Natural (NT) Ultra Flex® Pro cuts easily with scissors, and special heat treated construction minimizes fraying and dusting during assembly. Expands Up To 50% For Easy Installation Material Fiberglass Grade FHH Wall Thickness Refer to Chart www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 “...will withstand extreme heat... provides the protection needed” VW-1 EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION Medium Rating________________________ VW-1 Maximum Continuous Mil-I-23053 1,202°F (650°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 75°F Humidity 72% Individual Fibers Visibly Broken 150 Test Cycles Braid Worn Through In One Direction 500 Test Cycles Material Destroyed 525 Test Cycles Pre-Test Weight *20,831.10 mg Post-Test Weight *19,203.20 mg Test End Loss Of Mass Point Of Destruction 1,140.51 mg *Weight Includes Mounting Card CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 2 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter__________NA ASTM D-204 Flammability Rating____________ VW-1 Recommended Cutting________Scissor Colors__________________________ 1 Wall Thickness____________ .025”-.035” Tensile Strength (Yarn)______________ ASTM D-2256 Lbs Specific Gravity ASTM D-792____1.0-1.8 Moisture Absorption_____________ .01 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML___________________________ .01 CVCM_________________________ .00 WVR___________________________ .00 Smoke D-Max_____________________ ASTM E-662 Outgassing____________________ Low Oxygen Index_____________________ ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY 2,048°F (1,120°C)
FHH1.00NT 价格&库存
很抱歉,暂时无法提供与“FHH1.00NT”相匹配的价格&库存,您可以联系我们找货
