ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
W
rappable Design For Easy
Installation And removal
Nominal
Size
Part
Flat
Width
3/4”
GWN0.75BK 2 15/16”
1”
GWN1.00BK
4 7/16”
1 3/8” GWN1.38BK
5 5/16”
Extra Flexible Construction
3/4”
GWX0.75BK
3 1/8”
M
ore Excellent Protection
Against Cut-Through, Abrasion
And Impact
C
losure Maintains Low Profile
For Flat Cables & Harnesses
Monofilament
Diameter
Bulk
Box
Shop
Spool
Available
Colors
Lbs/
100’
.010”
.010”
.010”
50’
50’
50’
25’
25’
25’
Black
Black
Black
2.00
3.00
4.00
.010”
50’
25’
25’
4.00
M
elt Temp. 482°F
One Size - Multiple Possibilities
Adjustable Diameter Sleeve with Easy On, Easy Off Access
GRIPWRAP® (GWN) is a lightweight, abrasion resistant sleeving with a unique hook
sealing system that eliminates spot taping and does not require an open end for
installation. The sleeving permits easy access for inspection, rework or replacement
of components. GripWrap® provides cut-through and abrasion protection, and is easily
applied to areas restricted by breakouts and large end fittings. Can be used to bundle
wire harnesses, and also can be used to substitute molded channels.
Cut Cleanly
Hot Knife
The unique GripWrap® system provides a variety of sealing and mounting options to
accommodate any harnessing or cable management application.
Material
Polyethylene Terephthalate
Colors Available:
Black (BK)
Grade
GWN
Monofilament Diameter
.010”
Drawing Number
TF001FWPT-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
High
Rating______________________UL94VO
482°F (250°C)
Maximum Continuous
Mil-I-23053
257°F (125°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .010”
ASTM D-204
Flammability Rating____________ UL94
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness_________________ .025”
Tensile Strength (Yarn)____________ 7.5
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2022 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
12-06
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
很抱歉,暂时无法提供与“GWX0.75BK”相匹配的价格&库存,您可以联系我们找货
