166-90274
166-90274
    HELLERMAN(海尔曼太通)
166-90274 数据手册
Routing, Protection & Insulation HelaGuard Non-Metallic Conduits T E C H N I CAL D A T A S H E E T Standard Weight Nylon HGSW Series A standard weight corrugated conduit made of PA6 nylon that offers flexible abrasion protection for wire and cable bundles. Easy to cut and use, the material is highly resistant to solvents and oils. Combine with HelaGuard Non Metallic Fittings for IP66 rating or greater protection against water, wind and dirt. Conduit Size Euro Size Pitch HellermannTyton Part Number Manufacturer Part Reference Outside Dimension (OD) Inside Dimension (ID) Minimum Bend Radius Compression Strength Weight in. mm (NW) F or C in mm in mm mm kg/100mm lbs / foot 5/16 13 10 F HG-SW0310 FPAS13 0.51 13.0 0.39 9.8 25 75 0.019 3/8 16 12 F HG-SW0380 FPAS16 0.63 15.8 0.47 11.8 35 60 0.026 1/2 21 17 F HG-SW0500 FPAS21 0.84 21.2 0.66 16.7 45 75 0.04 3/4 28 23 F HG-SW0750 FPAS28 1.13 28.5 0.90 22.8 50 70 0.067 1 34 29 C HG-SW1000 FPAS34 1.36 34.5 1.11 28.1 60 90 0.091 1.25 42 36 C HG-SW1250 FPAS42 1.68 42.5 1.40 35.5 70 100 0.111 1.5 54 48 C HG-SW1500 FPAS54 2.15 54.5 1.86 47.2 80 100 0.158 Technical Properties and Performance Property Rating Material: Standard Weight Nylon Polyamide Nylon 6 (PA6) Highly Flexible with excellent fatigue life Yes IP (Ingress Protection) rating with HG (FPA) fittings IP66 IP (Ingress Protection) rating with HGL (FPAX) fittings IP66+67+68+69K Temperature Range-Static -40°C to +120°C Temperature Range-Dynamic -20°C to +100°C Displays self recovery if crushed Yes Water and Dust resistant Yes Abrasion Resistant Yes High Impact Strength (at -25° C) > 6 Joules Vibration and Shock Resistance to EN 61373 Cat 2 (TUV Report 75908286) Yes UV Resistance (UL Report No. 13CA50836) Yes UL Recognized (File No. E229161) Yes 34mm, 42mm and 54mm UL Listed and CUL approved (File E246572) Yes Lloyds Register Type Approval Yes Compression Strength: (Tested at 21mm size) Pull-off (Tensile) Strength (Tested at 21mm size) Country of Origin 75kg/100mm 40kg HG & HGL fittings United Kingdom Fire Performance Limiting Oxygen index to ISO 4589 (RAPRA Report No. 38985) halogenfree 26.40% Flame Retardancy to UL 94 (RAPRA Report No. 39933) V2 Ignition and fune rating to NFF16-101/2 (RAPRA Report No. 43386) Maximum smoke opacity to BS6853 annex DD8.3 (RAPRA report 38985) I4F1 A = 0.02 º Toxicity Index to BS6853 B.1 (WFRC Report No. 141180) r = 1.55 Toxicity Index to NFX70-100 (WFRC Report No. 141180) CIT = 29.93 Self extinguishing to EN61386-1 (BSI Report No. 2381/7847798) Yes Halogen Sulphur and Phosphorous free Yes Warranty Policy HellermannTyton products are warranted to be free from defects in material and workmanship at the time sold by us; but our obligation under this warranty and that of the seller is limited to the replacement of the product, and neither we nor the seller are bound by any other warranty, expressed, implied or statutory. Under no circumstances are we or the seller liable for any loss, damage, expenses or consequential damages of any kind arising out of the use or inability to use these products. All are sold with the understanding that the user will test them in actual use and determine their adaptability for the intended uses. Every effort is made to ensure accuracy and completeness when describing the technical properties of these products. For product information visit www.hellermann.tyton.com or call 800.537.1512
166-90274 价格&库存
很抱歉,暂时无法提供与“166-90274”相匹配的价格&库存,您可以联系我们找货
