ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
E
asy, Cost And Labor
Effective Installation
M
ore Flexible Than Split
Convoluted Or Spiral Wrap
2
5% Edge Overlap
S
oft And Quiet In High
Vibration Uses
C
ut And Abrasion Resistant
Nominal
Size
Part
Wall
Thickness
Monofilament
Diameter
Bulk
Box
Box
A
Box
B
Available
Colors
Lbs/
100’
1/8”
1/4”
3/8”
1/2”
3/4”
1”
1 1/4”
1 1/2”
2”
F6N0.13
F6N0.25
F6N0.38
F6N0.50
F6N0.75
F6N1.00
F6N1.25
F6N1.50
F6N2.00
.024”
.025”
.025”
.025”
.025”
.038”
.038”
.038”
.038”
.008”
.010”
.010”
.010”
.010”
.015”
.015”
.015”
.015”
8,000’
3,000’
1,500’
1,200’
500’
400’
250’
250’
200’
400’
200’
150’
150’
100’
100’
75’
75’
50’
100’
100’
75’
75’
50’
50’
25’
25’
25’
BK,OR,PG,CW
5
5
5
5
5
5
5
5
0.47
0.60
1.20
1.40
1.60
2.00
2.40
2.70
3.60
C
hemically Inert
H
alogen Free
Flexible, Semi-Rigid
Wrappable Split Braided Tube
F6’s unique split, semi-rigid braided construction
makes it the ideal solution for situations where
ease of installation is of primary importance.
The lateral split allows the tube to open up
to accommodate a wide variety of bundling
requirements, and the semi-rigid braid
configuration simply closes around the entire
installation without the need for any additional
fasteners (Velcro, tape, etc.)
Cut Cleanly
Hot Knife
Material
Polyethylene Terephthalate
The PET braid is lightweight, quiet and flexible. The 25%
edge overlap (at nominal diameter) allows coverage
around inline plugs, connectors and splices.
F6 will bend to a tight radius without distorting
or splitting open and, unlike full rigid tubing, will
not impair or affect the flexibility of harnesses.
Colors Available:
Grade
F6N
Monofilament Diameter
.008” - .015”
Black (BK), Orange (OR), Platinum Gray (PG),
Clear/White (CW), & White (WH).
Drawing Number
TF001F6-WD
The large overlap allows easy
installation over splices and
incline connectors without
exposing wires and cables.
Nominal Diameter
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
FAR-25
Colors Available:
5= BK, OR, PG, CW,
and WH
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
High
FLAMMABILITY
Rating______________________UL94VO
FMVSS 302 and SAE J369_________Pass
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
74%
Some Scuffing Visible
500 Test Cycles
Significant Wear Is Visible
With Several Braid
Filaments Broken
1,200 Test Cycles
Material Destroyed
1,950 Test Cycles
Pre-Test Weight
5,365.1 mg
Post-Test Weight
4,850 mg
Test End Loss Of Mass
Point Of Destruction
515.1 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
482°F (250°C)
Maximum Continuous
Mil-I-23053
257°F (125°C)
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter___ .008”-.015”
ASTM D-204
Flammability Rating____________ UL94
Recommended Cutting______Hot Knife
Colors__________________________ 5
Wall Thickness____________.024”-.038”s
Tensile Strength (Yarn)___________6-10
ASTM D-2256 Lbs
Specific Gravity ASTM D-792______ 1.38
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data ASTM E-595
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2023 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
03-07
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
ASTM D-2117
很抱歉,暂时无法提供与“F6N1.00OR100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1247.820401+161.42462
