FWN0.75WH
FWN0.75WH
    TECHFLEX
    SELFWRAP3/4"X100'WHITE
FWN0.75WH 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups H  eavy Duty Hook And Loop Closure For Frequent Access E  xpands To Fit Over Inline Connectors And Splices C  ut And Abrasion Resistant Nominal Size Part # Hook & Loop Width Recommended Application Diameter Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/2” 3/4” 1 1/4” 2” 2 1/2” FWN0.50 FWN0.75 FWN1.25 FWN2.00 FXN2.50BK 1/4” 5/8” 5/8” 5/8” 5/8” 0.50” 0.50” 1.00” 1.25” - 100’ 100’ 100’ 100’ 100’ 20’ 15’ 12’ 10’ 10’ 4 4 4 4 BK 1.30 1.80 2.30 3.20 3.75 H  alogen Free Flexible, Control & Management With Easy On, Easy Off Access FLEXO® WRAP (FW) is an exclusive product engineered and manufactured by Techflex®s. FW provides the perfect solution to a wide variety of unique application challenges. The color matched hook and loop closure provides for easy on and off installation, as well as instant and convenient access for harness break-outs and rework of any specific section along the entire length of the run. Combined with the expandable, open weave design, FW will conform to a wide variety of bundle diameters and will wrap around irregular shapes. Cut Cleanly Hot Knife Colors Available: Material Polyethylene Terephthalate 4 = BK, WH, GY and BE. Grade FWN Monofilament Diameter .010” Drawing Number TF001FWN-WD Easy and secure cable organization. Colors Available: www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Black (BK), White (WH), Gray (GY) and Beige (BE). GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium Rating______________________UL94VO Maximum Continuous Mil-I-23053 257°F (125°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 70°F Humidity 63% Visible Hole Through Material Destroyed 900 Test Cycles Pre-Test Weight 3,772.7 mg Post-Test Weight 3,391.1mg Test End Loss Of Mass Point Of Destruction 381.6 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -94°F (-70°C) www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 482°F (250°C) PHYSICAL PROPERTIES Monofilament Diameter________ .010” ASTM D-204 Flammability Rating____________ UL94 Recommended Cutting______Hot Knife Colors__________________________ 4 Wall Thickness_________________ .025” Tensile Strength (Yarn)____________ 7.5 ASTM D-2256 Lbs Specific Gravity_________________ 1.38 ASTM D-792 Moisture Absorption____________ .1-.2 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 TML___________________________ .19 CVCM_________________________ .00 WVR___________________________ .16 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ Med Oxygen Index___________________ 21 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
FWN0.75WH 价格&库存
很抱歉,暂时无法提供与“FWN0.75WH”相匹配的价格&库存,您可以联系我们找货
