F6W1.75BK
F6W1.75BK
    TECHFLEX
    SELFWRAP1-3/4"X50'BLACK
F6W1.75BK 数据手册
ADVANCED ENGINEERING GENERAL PURPOSE Technical Data Sheet Technical Data Sheet Put-Ups H  igh Coverage, Self-Wrapping Design E  asy, Cost Effective Installation M  ore Flexible than Split Convoluted or Spiral Wrap I deal For Protecting Components Without Disconnecting Them M  elt Temp. 482°F Standard Put-Ups Nominal Size Part # Wall Thickness Bulk A B 1/8” 3/16” 1/4” 5/16” 3/8” 1/2” 5/8” 3/4” 1” 1 1/2” 1 3/4” 2” F6W0.13 F6W0.19 F6W0.25 F6W0.31 F6W0.38 F6W0.50 F6W0.63 F6W0.75 F6W1.00 F6W1.50 F6W1.75 F6W2.00 .027” .027” .027” .027” .027” .027” .027” .027” .027” .027” .027” .027” 1,800’ 1,200’ 925’ 650’ 450’ 300’ 250’ 150’ 100’ 50’ 50’ 40’ 900’ 600’ 450’ 325’ 225’ 150’ 125’ 100’ 75’ 25’ 10’ 10’ 300’ 200’ 200’ 125’ 100’ 75’ 75’ 50’ 50’ - Available Colors BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, BK, Woven, Split Tubular Harness Wrap WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, WH, Overlap *A Lbs/ 100’ 40% 51% 44% 40% 41% 35% 30% 28% 26% 23% 23% 23% 0.57 0.98 1.10 1.30 1.50 1.80 2.10 2.40 3.20 4.50 5.00 6.00 CB CB CB CB CB CB CB CB CB CB CB CB Colors Available: Woven Wrap has been engineered from the ground up to meet the demanding specifications of today’s modern wiring harness industry. Black (BK), White (WH), & Carbon (CB). F6W utilizes many of the same characteristics as our original F6 split braided sleeving including the easy wrap around design and the extra overlap to insure complete protection of important electronic communication and power systems. Cut Cleanly Hot Knife Material PET Polyethylene Terephthalate Grade F6W The new woven construction provides superior elastic flexibility with unbeatable coverage over any harness assembly. Through a unique process, the blend of monofilament and multifilament polyester fibers are formed into a sleeving with memory that causes the sleeve to self-close, and also snap back when opened. Wire harness professionals will also appreciate the increased abrasion resistance F6W will provide to their cable assemblies. Colors Available: Filament Diameter Overlap Width .009” Monofilament Polyester 1200 Denier Multifilament Drawing Number TF001F6W-WD Black (BK), White (WH), & Carbon (CB). Nominal Diameter The Right Overlap For Your Harness www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 *A The engineered overlap allows ideal flexibility without exposing wires and cables. GENERAL PURPOSE ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Low Rating______________________UL94VO Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 72°F Humidity 78% Moderate Scuffing Visible 125 Test Cycles Significant Scuffing; Braid Separated Approx. 20% 225 Test Cycles Braid Begins to Break; Material Destroyed 300 Test Cycles Pre-Test Weight 9,736.4 mg Post-Test Weight 9,328.6 mg Test End Loss Of Mass Point Of Destruction 407.8 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808_________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 482°F (250°C) PHYSICAL PROPERTIES Filament Diameter:_________________ Monofilament Polyester_______ .009” MultiFilament__________ 1200 Denier Recommended Cutting______Hot Knife Colors__________________________ 3 Wall Thickness_________________ .027” Tensile Strength________________6-10 Specific Gravity_________________ 1.38 Moisture Absorption%___________ .1-.2 Hard Vacuum Data _________________ ASTM E-595 at 10-5 torr TML (%)________________________ .19 CVCM (%)______________________ .00 WVR (%)_______________________ .16 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
F6W1.75BK 价格&库存
很抱歉,暂时无法提供与“F6W1.75BK”相匹配的价格&库存,您可以联系我们找货
