F6V0.38TB250
F6V0.38TB250
    TECHFLEX
    F6 WOVEN WRAP 3/8" BK/WHT 250'
F6V0.38TB250 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Nom inal Diam eter Hoo k& Widt Loop h Technical Data Sheet Complies to HL2 According to the Railway Standard DIN EN 45545-2 U  L and VW-1 P  asses Smoke Density Test ASTM E-662 P  asses Surface Flammability Test ASTM E-162 P  asses Smoke Toxicity Test SMP 800-C M  elt Temp. 482°F Cuts Cleanly Hot Knife Material PET Polyethylene Terephthalate Grade F6V Put-Ups Standard Put-Ups Nominal Size Part # Wall Thickness Bulk A B Available Colors Overlap *A Lbs/ 100’ 3/16” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” F6V0.19TB F6V0.38TB F6V0.50TB F6V0.75TB F6V1.00TB F6V1.25TB F6V1.50TB .027” .027” .027” .027” .027” .027” .027” 3,000’ 2,000’ 1,500’ 1,000 460’ 330’ 260’ 500’ 250’ 200’ 150’ 100’ 75’ 50’ 100’ 100’ 75’ 50’ 50’ 25’ 25’ TB TB TB TB TB TB TB 51% 41% 35% 28% 26% 25% 23% 0.8 1.2 1.6 2.5 3.2 3.7 4.8 Woven, Flame Retardant Split Tubular Harness Wrap F6 Woven Wrap FR (F6V) is a VW-1 Rated version our industry recognized F6 Woven Wrap, with the added advantage of a flame inhibitor to provide an extra level of safety. It utilizes many of the same characteristics as our original F6 split braided sleeving including the easy wrap around design and the extra overlap to ensure complete protection of important electronic communication and power systems. The new woven construction provides superior elastic flexibility with unbeatable coverage over any harness assembly. Through a unique process, the blend of monofilament and multifilament polyester fibers are formed into a sleeving with memory that causes the sleeve to self close, and also snap back when opened. The combination of flame retardance, ease of installation, and complete coverage makes F6 Woven FR an ideal solution for many commercial and aerospace applications. Colors Available: Black w/White Tracer (TB) The Right Overlap For Your Harness Hook & Loop Width Filament Diameter .010” Monofilament Polyester 1200 Denier Multifilament Drawing Number TF001FWPT-WD *A Nominal Diameter The engineered overlap allows ideal flexibility without exposing wires and cables. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 VW-1 DIN EN 45545-2 ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet eter Diam nal Loop k& Hoo idth W i Nom Melt Point ABRASION Medium Rating ________________________ VW-1 Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 2 UV Light _________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________Yes RoHS___________________________Yes SVHC_________________________ None 482°F (250°C) Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117 PHYSICAL PROPERTIES Filament Diameter: Monofilament Polyester_____ .010” Multifilament________ 1200 Denier Flammability Rating: ___________VW-1 Self Extinguishing, Type A Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness_________________ .027” Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML (%)_______________________ .19 CVCM (%)______________________ .00 WVR (%)_______________________ .06 Smoke D-Max__________________ 275 Outgassing___________________ Med Oxygen Index___________________ 31 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
F6V0.38TB250 价格&库存
很抱歉,暂时无法提供与“F6V0.38TB250”相匹配的价格&库存,您可以联系我们找货
F6V0.38TB250
  • 1+1721.986001+223.85261
