DWT1.00BK25
DWT1.00BK25
    TECHFLEX
    TURTLE WRAP 1" BLACK 25'
DWT1.00BK25 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups 1  ,000 Denier Cordura, Double Coated with Proprietary High FR Neoprene E  xtreme, Oversized Hook And Loop Closure R  epels Liquids P  revents Damage From UV, Abrasion, Gasoline, Engine Chemicals And Salt Water R  esists & Sheds Sparks & Hot Spall Nominal Size Part # 1” 1 1/2” 1 3/4” 2” 2 3/8” 2 1/2” 3” 3 1/2” 4” 6” DWT1.00BK DWT1.50BK DWT1.75BK DWT2.00BK DWT2.38BK DWT2.50BK DWT3.00BK DWT3.50BK DWT4.00BK DWT6.00BK Wall Hook & Loop Thickness Width 0.02” 0.02” 0.02” 0.02” 0.02” 0.02” 0.02” 0.02” 0.02” 0.02” 3/4” 3/4” 1 1/2” 1 1/2” 1 1/2” 1 1/2” 1 1/2” 1 1/2” 1 1/2” 1 1/2” Bulk Spool Shop Spool 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ Available Colors Black Black Black Black Black Black Black Black Black Black Lbs/ 100’ BK BK BK BK BK BK BK BK BK BK 6.2 7.2 9.29 10.41 11.10 11.6 13.8 15.33 16.8 22.0 Protection Sleeve With Easy On, Easy Off Hook & Loop Closure TURTLE WRAP is made of 1,000 Denier Cordura, and double coated with proprietary high FR Neoprene. This protection sleeve is used for bundling and wrapping hoses and cables. The reusable sleeve features Mil-Spec extreme Hook & Loop closure which allows installation without disconnecting hoses and can reduce labor time by 70%. TURTLE WRAP is an excellent choice for weld cable or welding hose that is often dragged across the floor. This material resists sparks and hot spall. TURTLE WRAP is also used in sub-sea maintenance where barnacles, sea life and salt water can damage hoses. This sleeve is also heavily used on off-shore oil rigs. Cut Cleanly Scissor Material 1,000 Denier Cordura Colors Available: Black (BK) Grade DWT Wall Thickness .02” Drawing Number TF001DWT-TW This is a non-expandable product. Be sure to match your application diameter accurately. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 CORDURA® is a registered trademark of INVISTA. HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet Momentary Spot Heat up to 800ºF (427ºC) ABRASION Maximum Continuous 250ºF (121ºC) Extreme Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 69°F Humidity 50% Minimal Wear 5000 Test Cycles Wearing Very Thin Approx. 50% of Test Area 12,000 Test Cycles Material Destroyed 13,500 Test Cycles Pre-Test Weight 4,764.9 mg Post-Test Weight 3,555.4mg Test End Loss Of Mass Point Of Destruction 1,209.5 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 4 Strong Oxidants___________________ 4 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 2 Fungus ASTM G-21_________________ 1 RoHS___________________________ Yes Minimum Continuous -40ºF (-40ºC) PHYSICAL PROPERTIES Monofilament Diameter_________ NA Recommended Cutting________ Scissor Colors___________________________ 1 Wall Thickness___________________ .02” Specific Gravity__________________ 1.3 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 Abrasion Resistance
DWT1.00BK25 价格&库存
很抱歉,暂时无法提供与“DWT1.00BK25”相匹配的价格&库存,您可以联系我们找货
