TSN2.00SV100
TSN2.00SV100
    TECHFLEX
    THERMASHIELD FLAT 2" SILVER 100'
TSN2.00SV100 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet FLAT Put-Ups E  conomical And Easy To Install C  uts Easily With Scissors R  eflects Radiant Heat I nsulates Delicate Wires And Components R  esists Gasoline And Engine Chemicals Nominal Size Part # Wall Thickness ±0.006” Bulk Spool Shop Spool 1” 1 1/2” 2” 3” 4” 5” 6” 6 7/8” TSN1.00SV TSN1.50SV TSN2.00SV TSN3.00SV TSN4.00SV TSN5.00SV TSN6.00SV TSN6.88SV 0.025” 0.025” 0.025” 0.025” 0.025” 0.025” 0.025” 0.025” 250’ 250’ 250’ 250’ 250’ 200’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 50’ 50’ Available Colors Silver Silver Silver Silver Silver Silver Silver Silver Lbs/ 100’ (SV) (SV) (SV) (SV) (SV) (SV) (SV) (SV) 1.60 2.00 2.75 4.30 5.60 7.60 9.20 10.90 Reflective Aluminized Surface Bonded To Insulating Fiberglass THERMASHIELD® creates a buffer between your wires, hoses and cables and the high temperature environments they are required to perform in. ThermaShield® is engineered by laminating an aluminum heat shield to a layer of strong fiberglass insulation. This system provides superior protection from radiant heat by reflecting it away from sensitive electronics, wiring and hoses. Cut Cleanly Scissors THERMASHIELD® FLAT (TSN) protects surfaces exposed to extreme heat with TSN. An aluminum laminated fiberglass sheet with a full coating of permanent, high temperature adhesive, applies directly to any clean surface. Ideal solution for protecting delicate electronic component boxes mounted close to engines or other heat sources. When applied, the aluminum laminate reflects heat away and the insulating fiberglass backing protects the fragile contents from thermal damage and failure. Colors Available: Silver (SV) Material Aluminum Laminated Fiberglass Grade TSN Wall Thickness .025” When applied, the aluminum laminate reflects heat away and the insulating fiberglass backing protects the fragile contents from thermal damage and failure. Drawing Number TF001TS-WD www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 HALOGEN FREE FAR-25 EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet FLAT Melt Point ASTM D-2117 ABRASION Very High Rating______________Non Combustible Will not burn Abrasion Test Machine Calibrase H-18 Abrasion Test Load 500g Room Temperature 70°F Humidity 57% Foil Layer Worn Through 1,000 Test Cycle Fiberglass Layer Worn Through - Material Destroyed 1,300 Test Cycles Pre-Test Weight 10,804.3 mg Post-Test Weight 9,918.5 mg Test End Loss Of Mass Point Of Destruction 885.8 mg Mil-I-23053 491°F (255°C) Minimum Continuous -76°F (-60°C) Taber 5150 Abrasion Test Wheel Maximum Continuous CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes PHYSICAL PROPERTIES Flammability Rating__Non Combustible Recommended Cutting________Scissor Colors__________________________ 1 Wall Thickness_________________ .025” © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY 2,048°F (1,120°C)
TSN2.00SV100 价格&库存
很抱歉,暂时无法提供与“TSN2.00SV100”相匹配的价格&库存,您可以联系我们找货
