ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
T
ightly Woven Ballistic
Nylon Construction
H
eavy Duty Hook Closure
For Carpet Installation
R
epels Liquids
R
esists And Prevents
Damage From UV, Abrasion,
And Chemicals
Nominal
Size
Part
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
3”
DRN3.00BK
150’
4”
5”
DRN4.00
DRN5.00
150’
150'
25’
GY, BR, BL, GN, YL, BK
4.29
25’
25'
SS, GY, BR, BL, GN, YL, BK
5.26
7.00
Abrasion Protection For High-Traffic Carpeting With Easy On,
Easy Off Hook Closure
DURA-RACE (DR) is the solution for hiding and protecting wires that are exposed
on carpeted areas. Dura-Race is braided from a tightly woven ballistic nylon. With
industrial strength hook closure, this covering will adhere to most industrial and
high-traffic carpeting, making it easy to lay over wires, cables or hoses keeping
them protected from abrasion. Dura-Race tightly holds the application close to the
carpeting, avoiding trips or falls on free lying wires. DR provides greater abrasion
resistance and water repellency compared to other nylon sleeves.
Colors Available:
7=SS, GY, BR, BL, GN,
YL, BK.
Cut Cleanly
Scissor
Material
Ballistic Nylon
Best applied to:
Cut & Loop Pile
Loop Pile
Grade
DRN
Patterned Loop Pile
NOT recommended for:
Wall Thickness
.012”
Cut Pile
Dura Race Safety Stripe is a great safety
enhancement for offices and other cable
environments.
Drawing Number
TF100DR-WD
Colors Available:
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
SS
GY
BR
BL
GN
YL
BK
SPECIALTY
ADVANCED
ENGINEERING
ABRASION
Abrasion Resistance
Melt Point
Extreme
ASTM D-2117
410°F (374°C)
Abrasion Test Machine
Maximum Continuous
Mil-I-23053
Abrasion Test Wheel
200°F (93°C)
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
77°F
Humidity
72%
Beginning Of Graying
Abrasion Circle Pattern
100 Test Cycles
Beginning Of “Roughing”
Of Material 5%
13,000 Test Cycles
Additional “Roughing”
Of Material 20%
17,000 Test Cycles
Of Material 50%
19,000 Test Cycles
Material Destroyed
20,000 Test Cycles
Pre-Test Weight
5,082.20 mg
Post-Test Weight
3,941.69 mg
Test End Loss Of Mass
Point Of Destruction
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 4
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 2
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
Minimum Continuous
-60°F (-51°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________NA
ASTM D-204
Recommended Cutting________Scissor
Colors__________________________ 7
Wall Thickness_________________ .012”
Specific Gravity ASTM D-792______ 1.13
Moisture Absorption_____________ 2.7
% ASTM D-570
1,140.51 mg
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Taber 5150
很抱歉,暂时无法提供与“DRN5.00SS”相匹配的价格&库存,您可以联系我们找货
