KVN2.00YL25
KVN2.00YL25
    TECHFLEX
KVN2.00YL25 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups U  p To 20 Times Stronger Than Steel W  ill Not Melt, Burn Or Support Combustion S  tays Soft, Flexible And Pliable Throughout -274°F to 320°F Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool 1/4” 1/2” 3/4” 1” 1 1/4” 1 1/2” 2” KVN0.25YL KVN0.50YL KVN0.75YL KVN1.00YL KVN1.25YL KVN1.50YL KVN2.00YL 1/8” 1/4” 1/2” 3/4” 1” 1 1/4” 1 3/4” 5/16” 5/8” 7/8” 1 1/4” 1 5/8” 2” 2 1/2” 500’ 250’ 250’ 200’ 125’ 100’ 100’ 50’ 50’ 50’ 25’ 25’ 25’ 25’ Stronger Than Steel, Soft And Pliable FLEXO ARAMID (FA) is a soft, flexible sleeving that’s perfect for bundling and protecting vulnerable components from the most extreme environmental conditions. Flexo Aramid is braided from aramid fibers and has all well-known characteristics of durability, pliability and extraordinary tensile strength. Flexo Aramid fibers are up to 20 times stronger than steel fibers of equal diameter. Cut Cleanly Flexo Aramid Shears Material *Kevlar® Aramid Fibers Flexo Aramid has excellent thermal stability, permitting long-term, continuous use at temperatures as low as -274°F and as high as 320°F. Short term exposure up to 572°F can be tolerated. Flexo Aramid does not melt or support combustion. The sleeving provides extreme strength and durability, yet is lightweight and easy to install. Grade KVN The properties that make Flexo Aramid so tough in use also make the material a challenge to cut to length. Use Flexo Aramid shears for cutting. Wall Thickness .020” Drawing Number TF001KV-WD NEW- Ask about our high speed cutting service. Cuts Flexo Aramid to precise, repeatable lengths! *Kevlar® is a registered trademark of DuPontTM. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 Available Colors Yellow Yellow Yellow Yellow Yellow Yellow Yellow (YL) (YL) (YL) (YL) (YL) (YL) (YL) Lbs/ 100’ 0.30 0.80 1.20 1.92 2.40 2.90 3.60 Colors Available: Yellow (YL) ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point 572°F (300°C) ABRASION Maximum Continuous 320°F (160°C) Medium Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 70% Scuffing And Pulling Of Soft Fibers 20 Test Cycles Scuffing And Pulling Of Fibers Continues 400 Test Cycles Material Destroyed 700 Test Cycles Pre-Test Weight 5,730.5 mg Post-Test Weight 5,200.1 mg Test End Loss Of Mass Point Of Destruction 530.4 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 2 Chlorinated Solvents_______________ 2 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 4 Petroleum________________________ 1 Fungus ASTM G-21_________________ 2 Halogen Free____________________ Yes RoHS______________________________ SVHC______________________________ Minimum Continuous -274°F (-170°C) PHYSICAL PROPERTIES Monofilament Diameter_________ NA ASTM D-204 Flammability Rating_________________ FMVSS-302 Approved Cutting__________ Flexo Aramid Shears Colors___________________________ 1 Wall Thickness___________________ .02” Tensile Strength (Yarn)_____________ 39 ASTM D-2256 Lbs Specific Gravity ASTM D-792_____ 1.44 Moisture Absorption%_______________ ASTM D-570 Hard Vacuum Data__________________ ASTM E-595 at 10-5 torr TML__________________________3.13 CVCM_________________________ .19 WVR__________________________ 1.76 Smoke D-Max______________________ ASTM E-662 Outgassing____________________ High Oxygen Index____________________ 29 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 Abrasion Resistance
KVN2.00YL25 价格&库存
很抱歉,暂时无法提供与“KVN2.00YL25”相匹配的价格&库存,您可以联系我们找货
KVN2.00YL25
    • 1+1502.346861+194.35150
