ADVANCED ENGINEERING
Technical Data Sheet
Put-Ups
H
igh Cut Resistance
W
ill Not Melt, Burn Or
Support Combustion
L ight Weight
R
esists Acids, Bases,
Solvents, and Fuels
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/8”
1/4”
1/2”
1”
1 1/4”
KVX0.13BK
KVX0.25
KVX0.50
KVX1.00
KVX1.25
1/8”
1/4”
1/2”
1”
1 1/4”
1/4”
3/8”
1”
1 3/4”
2”
500’
500’
250’
200’
125’
100’
50’
50’
25’
25’
Black
BK &
BK &
BK &
BK &
1.02
1.69
3.22
4.76
5.88
BK
YL
YL
YL
YL
H
igh Tensile Strength
Soft, Lightweight, and Extraordinarily
Strong
Cut Cleanly
Flexo® Aramid Shears
Material
*Kevlar® Aramid Fibers
Grade
KVX
Extra heavy duty, tightly woven Aramid Armor®
is braided from aramid fibers, soft and pliable but
with 5 times strength of steel on equal-weight basis.
Aramid Armor® is perfect for bundling and
protecting vulnerable components from the most
extreme environmental conditions. The aramid fibers
provide durability, pliability and extraordinary tensile
strength.
It will not melt, burn or support combustion.
The inherent strength and heat resistance of Aramid
Armor® provides performance that can not be worn or
aged away. Typical uses include aerospace, marine, and
automotive industry applications.
Aramid Armor® sleeving is available in Yellow.
Colors Available:
Yellow (YL) and Black (BK).
Whenever your sleeving needs superior cut
protection, the cut and fire resistant properties
of Aramid Armor® will fill that need.
Wall Thickness
0.052”
Drawing Number
TF001KV-WD
*Kevlar® is a registered trademark of DuPontTM.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Colors Available:
Black (BK)
& Yellow (YL)
ADVANCED
ENGINEERING
ADVANCED
ENGINEERING
ABRASION
Maximum Continuous
Abrasion Resistance
Mil-I-23053
320°F (160°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
70%
Scuffing And Pulling
Of Soft Fibers
20 Test Cycles
Of Fibers Continues
400 Test Cycles
Material Destroyed
700 Test Cycles
Pre-Test Weight
5,730.5 mg
Post-Test Weight
5,200.1 mg
Test End Loss Of Mass
Point Of Destruction
530.4 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents__________________ 2
Aliphatic Solvents___________________ 2
Chlorinated Solvents________________2
Weak Bases________________________ 1
Salts______________________________ 1
Strong Bases_______________________ 2
Salt Water 0-S-1926__________________ 1
Hydraulic Fluid MIL-H-5606____________ 1
Lube Oil MIL-L-7808__________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids_______________________ 2
Strong Oxidants____________________2
Esters/Ketones_____________________2
UV Light _________________________ 4
Petroleum_________________________ 1
Fungus ASTM G-21__________________2
Halogen Free____________________ Yes
RoHS____________________________Yes
Minimum Continuous
-274°F (-170°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________ NA
ASTM D-204
Cutting__________ Flexo Aramid Shears
Colors___________________________ 2
Wall Thickness_________________0.052”
Tensile Strength (Yarn)_____________ 39
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_____ 1.44
Moisture Absorption %______________
ASTM D-570
Hard Vacuum Data__________________
ASTM E-595 at 10-5 torr
TML__________________________3.13
CVCM_________________________ .19
WVR___________________________ .76
Smoke D-Max_____________________
ASTM E-662
Outgassing ___________________ _High
Oxygen Index_____________________29
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06-21
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Medium
很抱歉,暂时无法提供与“KVX1.25YL25”相匹配的价格&库存,您可以联系我们找货
