NXN1.00GN25
NXN1.00GN25
    TECHFLEX
    NOMEX SLEEVING 1" GREEN 25'
NXN1.00GN25 数据手册
ADVANCED ENGINEERING Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups S  oft, Pliable And Strong E  xceptional Thermal Stability P  rotects To 662°F Resists Gasoline And Engine Chemicals C  ut And Abrasion Resistant Expansion Range Nominal Size Part # Min. Max. Bulk Spool Shop Spool 1/8” 1/4” 5/16” 3/8” 1/2” 5/8” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” NXN0.13 NXN0.25 NXN0.31 NXN0.38 NXN0.50 NXN0.63 NXN0.75 NXN1.00 NXN1.25 NXN1.50 NXN1.75 1/16” 1/8” 7/32” 1/4” 5/16” 7/16” 9/16” 3/4” 1” 1 1/4” 1 1/2” 1/4” 5/16” 7/16” 1/2” 5/8” 7/8” 1” 1 1/8” 1 1/2” 1 3/4” 2” 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 100’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ Soft, Pliable Flame Protection To 662°F Braided Flexo NX is made from the same fibers of DuPont™ *Nomex® that have been in protective clothing used for years by race car drivers, municipal fire departments and oil rig personnel to provide that extra level of comfort and protection from the dangers that come with working in and around intense flame and heat. Our Flexo NX sleeving will do the same for your wires, hoses and cables. Cut Cleanly Scissors Material Polyaramid Polymetaphenylene Isophthalamide Flexo NX will protect your application in temperatures up to 662°F. It is unaffected by short term exposure to most acids, bases, solvents and common engineering chemicals. Despite the soft touch and smooth appearance associated with woven aramid fibers, Flexo NX is incredibly strong, with a tensile strength of 90,000 psi. Grade NXN Drawing Number TF001NX-WD Provides full coverage and protection on even the most exposed applications. Cuts easily with regular scissors and the smooth surface eases installation even over long wire runs. The construction allows slight expansion to accommodate irregular surfaces and tight turns. Colors Available: Green (GN) and Natural (NT). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 *Nomex® is a registered trademark of DuPontTM. Available Colors GN GN GN GN GN GN GN GN GN GN GN & & & & & & & & & & & NT NT NT NT NT NT NT NT NT NT NT Lbs/ 100’ 0.12 0.50 0.60 0.67 0.91 1.10 1.34 2.42 3.49 4.03 4.76 Colors Available: 2 = GN and NT ADVANCED ADVANCED ENGINEERING ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION FLAMMABILITY 662°F (350°C) Maximum Continuous Mil-I-23053 Does Not Melt or Flow Below 662°F/350°C Abrasion Test Machine Retains its integrity at temperatures over 489°F/254°C (the melting point of Nylon) Minimum Continuous or in presence of Beta, Gamma and X-Ray -76°F (-60°C) Radiation or when exposed to High Humidity or Moisture. Low Taber 5150 Abrasion Test Wheel Calibrase H-18 428°F (220°C) Abrasion Test Load 500g Room Temperature 80°F Humidity 70% Material Very Visibly Being Pulled Apart 25 Test Cycles Hole Through Material Destroyed 350 Test Cycles Pre-Test Weight 2271.03 mg Post-Test Weight 2097.67 mg Test End Loss Of Mass Point Of Destruction 173.36 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Strong Bases______________________ 1 Strong Acids______________________ 2 Strong Oxidants___________________ 2 UV Light_________________________ 2 Petroleum________________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes PHYSICAL PROPERTIES Monofilament Diameter__________ NA ASTM D-204 Flammability Rating__ Self Extinguishing FMVSS-302 Approved Recommended Cutting_______ Scissor Colors__________________________ 2 Wall Thickness________________ .016” Tensile Strength (Yarn)______________8 ASTM D-2256 Lbs Specific Gravity ASTM D-792_____ 1.38 Moisture Absorption_______________ 4 % ASTM D-570 Hard Vacuum Data ASTM E-595 TM__________________________ 3.94 CVCM_________________________ .18 WVR_________________________ 2.91 Oxygen Index____________________28 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance
NXN1.00GN25 价格&库存
很抱歉,暂时无法提供与“NXN1.00GN25”相匹配的价格&库存,您可以联系我们找货
