PKN0.25BK
PKN0.25BK
    TECHFLEX
    PEEK 1/4" BLACK 200'
PKN0.25BK 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups H  igh Chemical Resistance L ow Outgassing H  alogen Free V  ery Light Weight V  -O Flammability Rating W  ear Resistant H  igh Strength Alternative to Fluoropolymers Nominal Size Part # 1/8” 1/4” 3/8” 1/2” 5/8” 3/4” 1” 2” 2 1/2” PKN0.13BK PKN0.25BK PKN0.38BK PKN0.50BK PKN0.63BK PKN0.75BK PKN1.00BK PKN2.00BK PKN2.50BK Expansion Range Min Max 1/16” 7/64” 5/32” 3/16” 1/4” 3/8” 5/16” 9/16” 5/8” 15/16” 1 1/4” 1 3/8” Bulk Spool Shop Spool 1,000’ 1,000’ 500’ 500’ 500’ 250’ 250’ 200’ 200’ 225’ 200’ 125’ 100’ 100’ 75’ 65’ 50’ 50’ Available Colors Black Black Black Black Black Black Black Black Black (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) Lbs/ 100’ 0.16 0.19 0.31 0.44 0.51 0.64 0.71 2.14 Call for more size availability Secures Performance Of Sensitive Items in Challenging Environments Cut Cleanly Hot Knife Material Polyetheretherketone Grade PKN Monofilament Diameter .010” Drawing Number TF001PK-WD Similar to PPS, but with a substantially expanded operating temperature range, PEEK (PolyEtherEther-Ketone) is a high performance advanced polymer with outstanding physical properties. PEEK is inherently flame retardant, with a V-0 flammability rating, will withstand continuous use in superheated water or steam up to 500°F, and resists most acids, solvents and bases. PEEK is FDA approved as a food contact product, resists damage from radiation and will continue to perform in UHV (Ultra High Vacuum) environments. PEEK is extensively used in the aerospace, automotive, teletronic and chemical process industries, and is considered an advanced biomaterial used in medical implants and other biomedical applications. PEEK will withstand thousands of sterilization cycles without damage or degradation. Flexo PEEK expandable sleeving is tightly braided from 10 mil filaments of pure, unfilled PEEK polymer. The sleeving expands to fit over connectors and splices, and provides a full coverage over wires hoses and cable bundles in advanced engineering applications. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 Colors Available: Black (BK) PEEK® is a registered trademark of the Victrex Corporation. HALOGEN FREE UL94 V-O ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 633°F (334°C) FLAMMABILITY CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 3 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil__________________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 1 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes Mil-I-23053 500°F (260°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter_________ .010” Recommended Cutting______ Hot Knife Colors___________________________1 Wall Thickness________________.025” Abrasion Resistance____________ Med Tensile Strength_____________ 13,300 ASTM D638 (PSI) Specific Gravity ASTM D-792_______ 1.3 Water Absorption %___________ 500 ASTM D149 (V/Mil) Volume Resistivity________ >4.9x1016 ASTM D257 (ohm-cm) Outgassing___________________ Low © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06/18 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Rating_________________________ V-O Maximum Continuous
PKN0.25BK 价格&库存
很抱歉,暂时无法提供与“PKN0.25BK”相匹配的价格&库存,您可以联系我们找货
