EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
UL Recognized
R
esin Coated, Heavy Weight
Fiberglass Won’t Burn, Melt
Or Become Brittle
E
asy To Install-Cuts With
Scissors
R
esists Gasoline And
Engine Chemicals
Nominal
Size
Part
Maximum
Diameter
Wall
Thickness
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/4”
3/8”
1/2”
5/8”
3/4”
7/8”
1”
1 1/2”
2 1/2”
FGN0.25
FGN0.38
FGN0.50
FGN0.63
FGN0.75
FGN0.88
FGN1.00
FGN1.50
FGN2.50
3/8”
5/8”
3/4”
7/8”
1 1/8”
1 1/4”
1 5/8”
2 5/8”
4 1/8"
0.031”
0.043”
0.046”
0.046”
0.046”
0.046”
0.057”
0.061”
0.071"
200’
200’
200’
200’
200’
200’
100’
100’
100'
50’
50’
50’
50’
50’
50’
25’
25’
25'
2
2
2
2
2
2
2
2
2
2.00
3.30
4.80
5.30
6.40
8.70
10.50
16.00
19.70
Cut And Abrasion Resistant
Resin Coated Fiberglass
Protects To 1,200°F
INSULTHERM ® (FG) is an extremely high
temperature resistant sleeve commonly used
as thermal protection for wires, cables and hoses
that are subjected to continuous and extreme
high temperature environments, such as
engine manifolds and exhaust systems.
Cut Cleanly
Scissors
Material
2 = BK and SV
FG is braided from fiberglass yarns and coated
with high temperature resins. FG is tough and
durable, maintaining its tight structure under
extreme vibration, abrasion, mechanical stress
and temperature variations.
FG installs easily over a variety of applications
to either deflect or retain heat in environments
up to 1,200° F.
“...will withstand extreme heat...
provides the protection needed”
Grade
FGN
Wall Thickness
Refer to Chart
Colors Available:
Peter Mercier - Engineer Team Bucknum Racing
www.bucknum.com
Colors Available:
Drawing Number
TF001INS-WD
Black (BK) and Silver (SV).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
VW-1
EXTREME
TEMPERATURE
Melt Point
ASTM D-2117
ABRASION
High
Rating________________________ VW-1
Maximum Continuous
Mil-I-23053
1,202°F (650°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
73°F
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Humidity
55%
Visible Minor Scuffing
200 Test Cycles
Scuffing And Wear
Continues
300 Test Cycles
Scuffing And Wear
Continues
500 Test Cycles
Several Broken Strands
1,300 Test Cycles
Material Destroyed
1,650 Test Cycles
Pre-Test Weight
19,411.6 mg
Post-Test Weight
17,154.5 mg
Test End Loss Of Mass
Point Of Destruction
2,257.1 mg
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
Minimum Continuous
-94°F (-70°C)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ NA
ASTM D-204
Flammability Rating____________ VW-1
Recommended Cutting________ Scissor
Colors___________________________ 2
Wall Thickness_____________ .031”-.061”
Specific Gravity ASTM D-792____ 1.0-1.8
Moisture Absorption_____________ .01
% ASTM D-570
Hard Vacuum Data__________________
ASTM E-595
TML___________________________ .02
CVCM_________________________ .01
WVR___________________________ .00
Outgassing____________________Low
SVHC_________________________ None
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“FGN0.38SV”相匹配的价格&库存,您可以联系我们找货
