DWN4.50BK25
DWN4.50BK25
    TECHFLEX
    DURA WRAP 4 1/2" BLACK 25'
DWN4.50BK25 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups T  ightly Woven Ballistic Nylon Construction H  eavy Duty, Oversize Hook And Loop Closure R  epels Liquids R  esists And Prevents Damage From UV, Abrasion, Gasoline, Engine Chemicals And Salt Water Nominal Size Part # Wall Hook & Loop Thickness Width 1” 1 1/2” 2” 2 1/2” 3” 3 1/2” 4” 4 1/2” 6” 8” DWN1.00BK DWN1.50BK DWN2.00BK DWN2.50BK DWN3.00BK DWN3.50BK DWN4.00BK DWN4.50BK DWN6.00BK DWN8.00BK .026” .026” .026” .026” .026” .026” .026” .026” .026” .026” 1” 1” 1” 1” 1” 1” 1” 1” 1” 1" Bulk Spool Shop Spool 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 50' 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25' Available Colors Black Black Black Black Black Black Black Black Black Black BK BK BK BK BK BK BK BK BK BK Lbs/ 100’ 5.40 7.00 8.20 9.40 11.40 12.60 14.00 15.40 19.20 25.00 D  eflects High Pressure Hose Ruptures Harsh Environment Protection With Easy On, Easy Off Hook & Loop Closure DURA-WRAP (DW) is the answer to organizing and controlling wires, cables and hoses that are subjected to constant and extreme use. The flexible sleeve is made from tightly woven ballistic nylon with an aggressive, industrial strength hook and loop closure. DURA-WRAP is used on wires to keep them together, on hoses and cables to prevent abrasion damage and on chains to keep them from ruining expensive finished surfaces. DW provides greater abrasion resistance and water repellency compared to other nylon sleeves and is being tested for certification under the U.S. Dept. of Labor’s MSHA. Cut Cleanly Scissor DW is extremely flexible and easy to install over single or multiple hoses. In the event of a hose rupture, the high strength sleeving helps prevent high pressure fluid from becoming a danger to equipment operators and other personnel. Colors Available: Material Polyamide 6 Black (BK) Grade DWN Wall Thickness .026” Drawing Number TF001DWN-WD This is a non-expandable product. Be sure to match your application diameter accurately. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet Melt Point ABRASION ASTM D-2117 410°F (210°C) Mil-I-23053 Extreme 200°F (93.3°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 84°F Humidity 74% First Signs Of Slight Fraying 5,000 Test Cycles Visible Small Hole In Material 7,500 Test Cycles Material Destroyed 8,500 Test Cycles Pre-Test Weight 6,903.10 mg Post-Test Weight 5,911.80 mg Test End Loss Of Mass Point Of Destruction 991.30mg CHEMICAL RESISTANCE 1=No Effect 4=More Affected 2=Little Effect 5=Severely Affected 3=Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 4 Strong Oxidants___________________ 4 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 2 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC______________________________ Minimum Continuous -60°F (-51.1°C) PHYSICAL PROPERTIES Monofilament Diameter__________NA Flammability Rating________________ Recommended Cutting________Scissor Colors__________________________ 1 Wall Thickness_________________ .026” Tensile Strength (Yarn)______________ ASTM D-2256 Lbs Specific Gravity ASTM D-792______ 1.13 Moisture Absorption_____________ 2.7 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML__________________________ 1.10 CVCM_________________________ .01 WVR___________________________ .69 Smoke D-Max___________________ 56 ASTM E-662 Outgassing___________________ High Oxygen Index___________________ 22 ASTM D-2863 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Maximum Continuous Abrasion Resistance
DWN4.50BK25 价格&库存
很抱歉,暂时无法提供与“DWN4.50BK25”相匹配的价格&库存,您可以联系我们找货
DWN4.50BK25
  • 1+2245.684951+290.12072
  • 2+2065.405892+266.83042
  • 3+1966.724523+254.08174
  • 5+1944.165225+251.16730
库存:3
