CCF1.25TB
CCF1.25TB
    TECHFLEX
    CLEAN CUT FR 1 1/4" BLK/WHT 250'
CCF1.25TB 数据手册
ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Put-Ups C  omplies to HL2 According to the Railway Standard DIN EN 45545-2 Cuts Easily, Neatly And Maintains a Fray Resistant End E  xpands For Ease of Installation C  ut And Abrasion Resistant Mil-202 & VW-1 Approved Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/8” 1/4” 3/8” 1/2” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 2” CCF0.13 CCF0.25 CCF0.38 CCF0.50 CCF0.75 CCF1.00 CCF1.25 CCF1.50 CCF1.75TB CCF2.00TB 1/8” 5/32” 3/16” 1/4” 5/8” 3/4” 1” 1 1/4” 1 1/2” 1 3/4” 1/4” 7/16” 5/8” 3/4” 1” 1 3/16” 1 1/2” 2” 2 1/8” 2 1/2” 1,000’ 1,000’ 500’ 500’ 250’ 250’ 250’ 250’ 200’ 200’ 100’ 100’ 100’ 100’ 75’ 50’ 50’ 50’ 50’ 50’ 2 2 2 2 2 2 2 2 TB TB 0.40 0.46 0.74 0.82 1.11 1.24 1.56 1.85 2.30 2.80 Scissor Cut For Field Installation, Will Not Support Combustion CLEAN CUT FR has all of the same qualities that make our standard CC so easy to cut and install, with the added advantage of a flame inhibitor to provide an extra level of safety in certain applications. Colors Available: 2 = TW & TB Under normal conditions, Clean Cut FR will quickly self-extinguish and minimize flame spread and incidental damage to surrounding components. Cut Cleanly Scissors Material Polyethylene Terephthalate The combination of flame retardance, ease of installation and nearly complete coverage makes CC an ideal solution for many industrial and engineering applications. Grade CCF Monofilament Diameter .008” Cuts easily and neatly with regular scissors and maintains a fray resistant end during installation. When scissor cut, the end of CC will withstand heavier handling without fraying than standard PT. Colors Available: Drawing Number TF001CCF-WD White w/Black Tracer (TW) and Black w/White Tracer (TB). www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 0787 FAR-25 VW-1 DIN EN 45545-2 ADVANCED ENGINEERING ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION Medium Rating______________________UL VW-1 Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 80°F Humidity 70% Very Minor Scuffing 100 Test Cycles Strands Frayed And Rough Surface 400 Test Cycles Scuffing And Several Broken Strands 500 Test Cycles Material Destroyed 700 Test Cycles Pre-Test Weight 3,602.0 mg Post-Test Weight 3,373.9 mg Test End Loss Of Mass Point Of Destruction 228.1 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents__________________ 2 Aliphatic Solvents __________________ 1 Chlorinated Solvents_______________ 3 Weak Bases ________________________ 1 Salts _____________________________ 1 Strong Bases________________________ 2 Salt Water 0-S-1926__________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808_________________ 1 De-Icing Fluid MIL-A-8243____________ 1 Strong Acids _______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones_____________________2 UV Light__________________________ 1 Petroleum_________________________ 1 Fungus ASTM G-211__________________ Halogen Free ____________________ Yes RoHS____________________________Yes SVHC_________________________ None 482°F (250°C) Maximum Continuous Mil-I-23053 257°F (125°C) Minimum Continuous -94°F (-70°C) PHYSICAL PROPERTIES Monofilament Diameter_________.008” ASTM D-204 Flammability Rating____________ VW-1 FMVSS-302 Approved Recommended Cutting_____Scissor/HK Colors__________________________ 2 Wall Thickness__________________.024” Tensile Strength (Yarn)______________ 4 ASTM D-2256 Lb Specific Gravity ASTM D-792______ 1.38 Moisture Absorption %__________ .1-.2 ASTM D-570 Hard Vacuum Data__________________ ASTM E-595 TML___________________________.19 CVCM_________________________ .04 WVR___________________________ .06 Smoke D-Max___________________275 ASTM E-66 Outgassing____________________Med Oxygen Index___________________ 31 ASTM D-2863 © 2020 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 01-07 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY ASTM D-2117
CCF1.25TB 价格&库存
很抱歉,暂时无法提供与“CCF1.25TB”相匹配的价格&库存,您可以联系我们找货
