NSN2.00BK
NSN2.00BK
    TECHFLEX
    SLEEVING2"X200'BLACK
NSN2.00BK 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups M  anages And Protects Cable Bundles I ncreased Safety In Foot Traffic Areas E  conomical And Easy To Install E  xpands Up To 150% C  ut And Abrasion Resistant Expansion Range Nominal Size Part # Min Max Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1/4” 3/8” 1/2” 5/8” 3/4” 1 1/4” 1 1/2” 2” NSN0.25 NSN0.38 NSN0.50 NSN0.63 NSN0.75 NSN1.25 NSN1.50 NSN2.00 1/8” 3/16” 1/4” 3/8” 1/2” 3/4” 1” 1 1/2” 7/16” 1/2” 3/4” 1” 1 1/4” 1 3/4” 2” 3 1/2” 1,000’ 500’ 500’ 500’ 250’ 200’ 200’ 200’ 200’ 125’ 100’ 75’ 70’ 50’ 40’ 50’ NY, BK, SS NY, BK, SS NY, BK, SS NY, BK, SS NY & BK NY, BK, SS NY, BK, SS NY & BK 0.44 0.57 0.89 1.04 1.25 1.96 2.25 2.75 Increased Friction On Smooth Surfaces Minimizes Slipping And Accidents FLEXO® NON-SKID (NS) is a unique combination of our standard PET material braided together with a matching thread of a high-friction polymer. NS is engineered primarily for wire and cable management in smooth floor, high traffic environments such as broadcast studios where someone might inadvertently step on a cable snake and slip. Cut Cleanly Hot Knife Material Polyethylene Terepthalate Grade NSN As long as there’s no excessive pressure on cables protected with NS, the entire snake glides easily and quietly along the floor. When local pressure is applied, such as someone stepping on the cable, the high friction material comes in contact with the floor and reduces the possibility of the cable sliding out from underfoot. NS is substantially less “slippery” than our regular PET, yet provides the same level of flexibility and protection from cable wear and abrasion. Monofilament Diameter .028” Non-Skid is ideal for smooth floor areas such as photo, film and TV studios where cable snakes, high foot traffic and low light combine to create a slipping hazard. Drawing Number TF001NS-WD Colors Available: www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Neon Yellow (NY), Black (BK) and Safety Stripe (SS). Colors Available: BK, NY, and SS SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet ABRASION Melt Point ASTM D-2117 Medium Mil-I-23053 Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 71°F Humidity 53% Braid (1 Carrier) Broken In One Direction 350 Test Cycles Material Destroyed Braid Broken In Both Directions 650 Test Cycles Pre-Test Weight 4,360.5 mg Post-Test Weight 4,147.0 mg Test End Loss Of Mass Point Of Destruction 213.5 mg CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 2 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 3 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 3 Strong Oxidants___________________ 2 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes 175°F (79°C) Minimum Continuous -40°F (-40°C) PHYSICAL PROPERTIES Monofilament Diameter________ .028” ASTM D-204 Recommended Cutting______Hot Knife Colors__________________________ 3 Wall Thickness__________________ .07” Specific Gravity ASTM D-792______ 1.38 Moisture Absorption____________ .1-.2 % ASTM D-570 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com 260°F (126°C) Maximum Continuous Abrasion Resistance
NSN2.00BK 价格&库存
很抱歉,暂时无法提供与“NSN2.00BK”相匹配的价格&库存,您可以联系我们找货
