ADVANCED ENGINEERING
HEAVY DUTY
Technical Data Sheet
Put-Ups
1
,000 Denier Cordura, Double
Coated with Proprietary
High FR Neoprene
E
xtreme, Oversized Hook
And Loop Closure
R
epels Liquids
P
revents Damage From UV,
Abrasion, Gasoline, Engine
Chemicals And Salt Water
R
esists & Sheds Sparks & Hot
Spall
Nominal
Size
Part
1”
1 1/2”
1 3/4”
2”
2 3/8”
2 1/2”
3”
3 1/2”
4”
6”
DWT1.00BK
DWT1.50BK
DWT1.75BK
DWT2.00BK
DWT2.38BK
DWT2.50BK
DWT3.00BK
DWT3.50BK
DWT4.00BK
DWT6.00BK
Wall
Hook & Loop
Thickness
Width
0.02”
0.02”
0.02”
0.02”
0.02”
0.02”
0.02”
0.02”
0.02”
0.02”
3/4”
3/4”
1 1/2”
1 1/2”
1 1/2”
1 1/2”
1 1/2”
1 1/2”
1 1/2”
1 1/2”
Bulk
Spool
Shop
Spool
150’
150’
150’
150’
150’
150’
150’
150’
150’
150’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
Available
Colors
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Lbs/
100’
BK
BK
BK
BK
BK
BK
BK
BK
BK
BK
6.2
7.2
9.29
10.41
11.10
11.6
13.8
15.33
16.8
22.0
Protection Sleeve With Easy On, Easy Off Hook & Loop Closure
TURTLE WRAP is made of 1,000 Denier Cordura, and double coated with proprietary high FR Neoprene. This protection sleeve is used for bundling and wrapping
hoses and cables. The reusable sleeve features Mil-Spec extreme Hook & Loop
closure which allows installation without disconnecting hoses and can reduce
labor time by 70%.
TURTLE WRAP is an excellent choice for weld cable or welding hose that is often
dragged across the floor. This material resists sparks and hot spall. TURTLE WRAP
is also used in sub-sea maintenance where barnacles, sea life and salt water can
damage hoses. This sleeve is also heavily used on off-shore oil rigs.
Cut Cleanly
Scissor
Material
Colors Available:
Black (BK)
Grade
DWT
Wall Thickness
.02”
Drawing Number
TF001DWT-TW
This is a non-expandable product. Be sure to
match your application diameter accurately.
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
CORDURA® is a registered trademark of INVISTA.
HEAVY
DUTY ENGINEERING
ADVANCED
Momentary Spot Heat
up to
800ºF (427ºC)
ABRASION
Maximum Continuous
250ºF (121ºC)
Extreme
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
69°F
Humidity
50%
Minimal Wear
5000 Test Cycles
Wearing Very Thin
Approx. 50% of Test Area
12,000 Test Cycles
Material Destroyed
13,500 Test Cycles
Pre-Test Weight
4,764.9 mg
Post-Test Weight
3,555.4mg
Test End Loss Of Mass
Point Of Destruction
1,209.5 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 4
Strong Oxidants___________________ 4
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 2
Fungus ASTM G-21_________________ 1
RoHS___________________________ Yes
Minimum Continuous
-40ºF (-40ºC)
PHYSICAL
PROPERTIES
Monofilament Diameter_________ NA
Recommended Cutting________ Scissor
Colors___________________________ 1
Wall Thickness___________________ .02”
Specific Gravity__________________ 1.3
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Abrasion Resistance
很抱歉,暂时无法提供与“DWT2.38BK25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2514.523721+323.95676
