ADVANCED
ENGINEERING
Technical Data Sheet
ADVANCED ENGINEERING
Put-Ups
S
oft, Pliable And Strong
E
xceptional Thermal
Stability
P
rotects To 662°F
Resists Gasoline And Engine
Chemicals
C
ut And Abrasion Resistant
Expansion Range
Nominal
Size
Part
Min.
Max.
Bulk
Spool
Shop
Spool
1/8”
1/4”
5/16”
3/8”
1/2”
5/8”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
NXN0.13
NXN0.25
NXN0.31
NXN0.38
NXN0.50
NXN0.63
NXN0.75
NXN1.00
NXN1.25
NXN1.50
NXN1.75
1/16”
1/8”
7/32”
1/4”
5/16”
7/16”
9/16”
3/4”
1”
1 1/4”
1 1/2”
1/4”
5/16”
7/16”
1/2”
5/8”
7/8”
1”
1 1/8”
1 1/2”
1 3/4”
2”
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
25’
Soft, Pliable Flame Protection To 662°F
Braided Flexo NX is made from the same fibers of
DuPont™ *Nomex® that have been in protective clothing used for years by race car drivers, municipal fire
departments and oil rig personnel to provide
that extra level of comfort and protection from
the dangers that come with working in and around
intense flame and heat. Our Flexo NX sleeving
will do the same for your wires, hoses and cables.
Cut Cleanly
Scissors
Material
Polyaramid Polymetaphenylene
Isophthalamide
Flexo NX will protect your application in
temperatures up to 662°F. It is unaffected by
short term exposure to most acids, bases, solvents
and common engineering chemicals. Despite the
soft touch and smooth appearance associated
with woven aramid fibers, Flexo NX is incredibly strong,
with a tensile strength of 90,000 psi.
Grade
NXN
Drawing Number
TF001NX-WD
Provides full coverage and protection on even
the most exposed applications. Cuts easily
with regular scissors and the smooth surface
eases installation even over long wire runs.
The construction allows slight expansion to
accommodate irregular surfaces and tight turns.
Colors Available:
Green (GN) and Natural (NT).
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 0787
*Nomex® is a registered trademark of DuPontTM.
Available
Colors
GN
GN
GN
GN
GN
GN
GN
GN
GN
GN
GN
NT
NT
NT
NT
NT
NT
NT
NT
NT
NT
NT
Lbs/
100’
0.12
0.50
0.60
0.67
0.91
1.10
1.34
2.42
3.49
4.03
4.76
Colors Available:
2 = GN and NT
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
ABRASION
FLAMMABILITY
662°F (350°C)
Maximum Continuous
Mil-I-23053
Does Not Melt or Flow Below
662°F/350°C
Abrasion Test Machine
Retains its integrity at temperatures over
489°F/254°C (the melting point of Nylon)
Minimum Continuous
or in presence of Beta, Gamma and X-Ray
-76°F (-60°C)
Radiation or when exposed to High Humidity or Moisture.
Low
Taber 5150
Abrasion Test Wheel
Calibrase H-18
428°F (220°C)
Abrasion Test Load
500g
Room Temperature
80°F
Humidity
70%
Material Very Visibly
Being Pulled Apart
25 Test Cycles
Hole Through
Material Destroyed
350 Test Cycles
Pre-Test Weight
2271.03 mg
Post-Test Weight
2097.67 mg
Test End Loss Of Mass
Point Of Destruction
173.36 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Strong Bases______________________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
UV Light_________________________ 2
Petroleum________________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
PHYSICAL
PROPERTIES
Monofilament Diameter__________ NA
ASTM D-204
Flammability Rating__ Self Extinguishing
FMVSS-302 Approved
Recommended Cutting_______ Scissor
Colors__________________________ 2
Wall Thickness________________ .016”
Tensile Strength (Yarn)______________8
ASTM D-2256 Lbs
Specific Gravity ASTM D-792_____ 1.38
Moisture Absorption_______________ 4
% ASTM D-570
Hard Vacuum Data ASTM E-595
TM__________________________ 3.94
CVCM_________________________ .18
WVR_________________________ 2.91
Oxygen Index____________________28
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
06/18
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
很抱歉,暂时无法提供与“NXN1.25GN25”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2653.981571+342.14942
