ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
Size = 1/16”
Expansion Range
Nominal
Size
Part
Min
Max
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/16”
1/4”
FTN0.06CL
FTN0.25CL
1/16”
1/8”
3/16”
1”
1,000’
500’
200’
200’
Clear
Clear
0.013
0.043
Ultra Thin, Ultra Light For
Specialized Fiber Applications
Braided from ultra fine nylon
monofilament fibers, Flexo® Thin was
created for applications where weight
and wall thickness play a critical role.
This material is strong enough to bundle
multiple cables and fibers while naturally
conforming to these type applications.
Size = 1/4”
Many of today’s micro optics and precision
electronic harnesses use Flexo® Thin to flexibly
and attractively manage and route tiny
assemblies.
Material
Nylon
Grade
FTN
Monofilament Diameter
.002” - .003”
Drawing Number
TF001FT-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Flexo® Thin’s enormous expandability allows
the management of large bundles of very fine
wiring and optical cables.
Colors Available:
Clear (CL).
SPECIALTY
ADVANCED
ENGINEERING
Melt Point
ASTM D-2117
ABRASION
428°F (220°C)
Maximum Continuous
248°F (120°C)
Low
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 5
Strong Oxidants___________________ 5
Esters/Ketones____________________ 1
UV Light_________________________ 2
Petroleum________________________ 2
Fungus ASTM G-21_________________ 3
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-49°F (-45°C)
PHYSICAL
PROPERTIES
Monofilament Diameter___ .002”-.003”
ASTM D-204
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness____________ .005”-.008”
Specific Gravity ASTM D-792______ 1.14
Moisture Absorption_____________ 2.5
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML__________________________ 1.10
CVCM_________________________ .01
WVR___________________________ .69
Outgassing___________________ High
Oxygen Index___________________ 22
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Abrasion Resistance
很抱歉,暂时无法提供与“FTN0.25CL”相匹配的价格&库存,您可以联系我们找货
