166-90266
166-90266
    HELLERMAN(海尔曼太通)
    SLITWRAP0.854"X328'BLACK
166-90266 数据手册
166-90266 Article Number: 166-90266 Description: HelaGuard Non-Metallic Conduit, Std. Weight, 0.75" Dia, Nylon PA12 Slit, Black, 100 ft/Std. Reel Base Data Local Order Number 166-90266 Type HG-HISL0750 Color Black (BK) Features and benefits ‡Very high impact strength; recovers completely if crushed and provides excellent fatigue life. ‡Highly UV resistant; suitable for use in outdoor applications. ‡Offered in fine or course corrugated pitch. ‡Offered with or without slit; slit options offer easy access during installation and maintenance. Quantity Per reel Product Description A standard weight corrugated conduit made of PA12 nylon that offers superior impact resistance, making it ideal for protecting wire and cable bundles in conditions with continual movement or bending. This material is highly resistant to UV light, solvents and oils. Combine with HelaGuard non-metallic fittings to achieve IP66 or greater protection against water, wind and dirt. Short Description HelaGuard Non-Metallic Conduit, Std. Weight, 0.75" Dia, Nylon PA12 Slit, Black, 100 ft/Std. Reel Length L (Imperial) 100.0ft Length L (Metric) 30.5m Inner Diameter D (Imperial) 0.86" Inner Diameter D (metric) 21.7mm Euro (NW) Size 23mm Pitch Type C (Coarse) Trade Size 3/4 " Outside Diameter D (imperial) 1.13" Outside Diameter D (metric) 28.5mm Nominal Diameter (Imperial) 3/4" Nominal Diameter (Metric) 28mm Inside Bend Radius (Imperial) 1.78" Product Dimensions generated on: 5/10/2017 166-90266 Product Dimensions Inside Bend Radius (Metric) 45mm Material Polyamide 12 (PA12) Material Shortcut PA12 Flammability self-extinguishing according to EN IEC 61386 Halogenfree Yes Operating Temperature -58°F to +230°F (-50°C to +110°C) ROHS Compliant Yes UL Recognized (US and Canada) Yes UL Recognized (US) Yes Package Quantity (Imperial) 100ft Package Quantity (Metric) 30.5m Customs Number(Schedule B) 3926909987 Material and Specifications Logistic and Packaging generated on: 5/10/2017
166-90266 价格&库存
很抱歉,暂时无法提供与“166-90266”相匹配的价格&库存,您可以联系我们找货
