EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
WRAP
Put-Ups
E
conomical And Easy
To Install
C
uts Easily With Scissors
R
eflects Radiant Heat
I nsulates Delicate Wires
And Components
R
esists Gasoline And
Engine Chemicals
Nominal
Size
Part
Sheet
Width
Wall
Thickness
±0.008”
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/2”
3/4”
1”
1 1/4”
1 1/2”
1 3/4”
2”
2 1/4”
TWN0.50SV
TWN0.75SV
TWN1.00SV
TWN1.25SV
TWN1.50SV
TWN1.75SV
TWN2.00SV
TWN2.25SV
1 13/16”
2 1/2”
3 3/8”
4 1/4”
5”
5 13/16”
6 11/16”
7 3/8”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
250’
250’
200’
200’
200’
100’
100’
100’
100’
100’
100’
100’
100’
50’
50’
50’
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
2.60
4.00
5.10
5.70
6.50
7.40
8.40
9.50
Reflective Aluminized Surface Bonded
To Insulating Fiberglass
Colors Available:
THERMASHIELD® creates a buffer between your wires,
hoses and cables and the high temperature environments they are required to perform in. ThermaShield® is
engineered by laminating an aluminum heat shield to a
layer of strong fiberglass insulation. This system provides superior protection from radiant heat by reflecting
it away from sensitive electronics, wiring and hoses.
Cut Cleanly
Scissors
Material
Aluminum Laminated Fiberglass
Grade
TWN
Silver (SV)
THERMASHIELD® WRAP (TWN). When component
disassembly isn’t an option, TWN is the solution.
Designed to fit securely around existing
assemblies and hard to reach components,
the flat material is joined along the edge with
a strip of permanent, high temperature adhesive.
The aggressive bonding agent will securely adhere
anywhere along the width of the material, affording
maximum protection and allowing a snug fit around
odd-shaped connectors and terminations.
Wall Thickness
.025”
When applied, the aluminum laminate
reflects heat away and the insulating
fiberglass backing protects the fragile
contents from thermal damage and failure.
Drawing Number
TF001TW-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
HALOGEN
FREE
FAR-25
EXTREME
TEMPERATURE
WRAP
Melt Point
ASTM D-2117
ABRASION
Very High
Rating______________Non Combustible
Will not burn
Abrasion Test Machine
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
70°F
Humidity
57%
Foil Layer Worn Through
1,000 Test Cycle
Fiberglass Layer Worn
Through - Material
Destroyed
1,300 Test Cycles
Mil-I-23053
491°F (255°C)
Minimum Continuous
-76°F (-60°C)
Taber 5150
Abrasion Test Wheel
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases_______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
PHYSICAL
PROPERTIES
Flammability Rating__Non Combustible
Recommended Cutting________Scissor
Colors__________________________ 1
Wall Thickness_________________ .025”
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“TWN1.75SV50”相匹配的价格&库存,您可以联系我们找货
