ADVANCED ENGINEERING
GENERAL PURPOSE
Technical Data Sheet
Put-Ups
H
eavy Duty Hook And Loop
Closure For Frequent Access
E
xpands To Fit Over Inline
Connectors And Splices
C
ut And Abrasion
Resistant
Nominal
Size
Part
Hook & Loop
Width
Recommended
Application Diameter
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/2”
3/4”
1 1/4”
2”
2 1/2”
FWN0.50
FWN0.75
FWN1.25
FWN2.00
FXN2.50BK
1/4”
5/8”
5/8”
5/8”
5/8”
0.50”
0.50”
1.00”
1.25”
100’
100’
100’
100’
100’
20’
15’
12’
10’
10’
4
4
4
4
BK
1.30
1.80
2.30
3.20
3.75
H
alogen Free
Flexible, Control & Management With Easy On, Easy Off Access
FLEXO® WRAP (FW) is an exclusive product engineered and manufactured by
Techflex®s. FW provides the perfect solution to a wide variety of unique
application challenges.
The color matched hook and loop closure provides for easy on and off installation, as well as instant and convenient access for harness break-outs and
rework of any specific section along the entire length of the run. Combined
with the expandable, open weave design, FW will conform to a wide variety of
bundle diameters and will wrap around irregular shapes.
Cut Cleanly
Hot Knife
Colors Available:
Material
Polyethylene Terephthalate
4 = BK, WH, GY
and BE.
Grade
FWN
Monofilament Diameter
.010”
Drawing Number
TF001FWN-WD
Easy and secure cable organization.
Colors Available:
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
Black (BK), White (WH), Gray (GY) and Beige (BE).
GENERAL
PURPOSE
ADVANCED
ENGINEERING
Melt Point
ABRASION
Medium
Rating______________________UL94VO
Maximum Continuous
Mil-I-23053
257°F (125°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
70°F
Humidity
63%
Visible Hole Through
Material Destroyed
900 Test Cycles
Pre-Test Weight
3,772.7 mg
Post-Test Weight
3,391.1mg
Test End Loss Of Mass
Point Of Destruction
381.6 mg
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 2
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 3
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 3
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-94°F (-70°C)
www.techflex.com
Abrasion Resistance
FLAMMABILITY
ASTM D-2117
482°F (250°C)
PHYSICAL
PROPERTIES
Monofilament Diameter________ .010”
ASTM D-204
Flammability Rating____________ UL94
Recommended Cutting______Hot Knife
Colors__________________________ 4
Wall Thickness_________________ .025”
Tensile Strength (Yarn)____________ 7.5
ASTM D-2256 Lbs
Specific Gravity_________________ 1.38
ASTM D-792
Moisture Absorption____________ .1-.2
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595
TML___________________________ .19
CVCM_________________________ .00
WVR___________________________ .16
Smoke D-Max___________________ 56
ASTM E-662
Outgassing___________________ Med
Oxygen Index___________________ 21
ASTM D-2863
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of
sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-28
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
很抱歉,暂时无法提供与“FXN2.50BK”相匹配的价格&库存,您可以联系我们找货
