FIF3.50SV25
FIF3.50SV25
    TECHFLEX
    3-1/2" FIREFLEX FLAT SILVER 25'
FIF3.50SV25 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put Ups E  asily Covers Irregularly Shaped Set Ups E  asily Secured With Wire Ties or Hose Clamps Nominal Size Part # Wall Thickness ±0.010” Bulk Spool Shop Spool Available Colors Lbs/ 100’ 3 1/2” FIF3.50 .094" 50’ 25’ SV, RD, BK 16.53 Protects From Extreme Heat, Open Flame, and Molten Splash High Temp, Silicone Coated Fiberglass Hose Wrap Fireflex Flat provides the same protection against exposure to extreme heat, open flame, and molten splash as the Fireflex Sleeve, but in a versatile tape. It is specifically designed to protect components of irregular shape, such as hose splitter assemblies and cable splices. The heavy silicone coating maintains flexibility while resisting all automotive chemicals and solvents, and providing an increased level or abrasion protection. Cut Cleanly Scissors Material Silicone Coated Fiberglass It is common for Fireflex Flat to be over-wrapped at 50%, providing a double layer of protection. Once installed, it can be easily secured with tie-wraps, wire ties, and hose clamps. Grade FIF The versatility of this tape allows for covering almost any irregular shape. Wall Thickness .094" www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 Colors Available: Red (RD), Silver (SV), Black (BK) EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet Melt Point ASTM D-2117 ABRASION Rating_______________ Non Flammable High Mil-I-23053 Abrasion Test Machine 500°F (260°C) Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Maximum Continuous CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected 4=More Affected 5=Severely Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 1 Strong Oxidants___________________ 2 Esters/Ketones____________________ 2 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC______________________________ Minimum Continuous -65°F (-54°C) PHYSICAL PROPERTIES Monofilament Diameter__________NA ASTM D-204 Flammability Rating___ Non Flammable Recommended Cutting________Scissor Colors__________________________ 3 Wall Thickness_________________ .094” Tensile Strength (Yarn)_______ Ex. High ASTM D-2256 Lbs Specific Gravity ASTM D-792_______NA © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY 2,048°F (1,120°C)
FIF3.50SV25 价格&库存
很抱歉,暂时无法提供与“FIF3.50SV25”相匹配的价格&库存,您可以联系我们找货
