166-90269
166-90269
    HELLERMAN(海尔曼太通)
166-90269 数据手册
Routing, Protection & Insulation HelaGuard Non-Metallic Conduits T E C H N I CAL D A T A S H E E T Standard Weight High Impact Nylon12 HGHI Series A standard weight corrugated conduit made of PA12 nylon that offers superior impact resistance, making it ideal for protecting wire and cable bundles in conditions with continual movement or bending. This material is highly resistant to UV light, solvents and oils. Combine with HelaGuard Non Metallic Fittings to achieve IP66 or greater protection against water, wind and dirt. Conduit Size Euro Size Pitch in. mm (NW) F or C 5/16 13 10 F HellermannTyton Part Number Manufacturer Part Reference HG-HI0310 FPI13 Outside Dimension (OD) Inside Dimension (ID) Minimum Bend Radius Compression Strength Weight in mm in mm mm kg/100mm lbs / foot 0.51 13.0 0.39 9.8 25 75 0.019 3/8 16 12 F HG-HI0380 FPI16 0.63 15.8 0.47 11.8 30 45 0.024 1/2 21 17 F HG-HI0500 FPI21 0.84 21.2 0.66 16.7 35 45 0.037 3/4 28 23 C HG-HI0750 FPI28 1.13 28.5 0.86 21.7 45 70 0.062 1 34 29 C HG-HI1000 FPI34 1.36 34.5 1.11 28.1 55 70 0.081 1.25 42 36 C HG-HI1250 FPI42 1.68 42.5 1.40 35.5 60 70 0.108 1.5 54 48 C HG-HI1500 FPI54 2.15 54.5 1.86 47.2 70 50 0.148 Technical Properties and Performance Property Rating Material: Standard Weight Nylon 12 Polyamide Nylon 12 (PA12) Highly Flexible with excellent fatigue life Yes IP (Ingress Protection) rating with HG (FPA) fittings IP66 IP (Ingress Protection) rating with HGL (FPAX) fittings IP66+67+68+69K Temperature Range -50°C to +110°C Displays self recovery if crushed Yes Water and Dust resistant Yes Abrasion Resistant Yes High Impact Strength (at -60° C) > 6 Joules UV Resistance (UL Report No. 13CA50836) Yes UL Recognized (File No. E229161) Yes Vibration and Shock resistance (EN61373) Cat 2 Compression Strength: (Tested at 21mm size) Pull-off (Tensile) Strength (Tested at 21mm size) 45kg/100mm 30kg HG & HGL fittings Country of Origin United Kingdom Fire Performance Limiting Oxygen index to ISO 4589 (RAPRA Report No. 197372) Maximum smoke opacity to BS6853 annex D8.3 (WFRC report 141493) Toxicity Index to BS6853 B.1 (WFRC Report No. 141181) Toxicity Index to NFX70-100 (WFRC Report No. 141181) 26.7% Aº = 0.045 R = 1.32 CIT = 24.99 Ignition and fune rating to NFF16-101/2 (RAPRA Report No. 43386) I4F2 Self extinguishing to EN61386-1 (BSI Report No. 2381 / 7847798) Yes Halogen, Sulphur and Phosphorous Free Burning Behavior to DIN5510 (CSI Report No. 15897) Smoke to ASTM E662 (Exova Report No. 14-002-307) Yes S4 SR2 ST2 Yes halogenfree Warranty Policy HellermannTyton products are warranted to be free from defects in material and workmanship at the time sold by us; but our obligation under this warranty and that of the seller is limited to the replacement of the product, and neither we nor the seller are bound by any other warranty, expressed, implied or statutory. Under no circumstances are we or the seller liable for any loss, damage, expenses or consequential damages of any kind arising out of the use or inability to use these products. All are sold with the understanding that the user will test them in actual use and determine their adaptability for the intended uses. Every effort is made to ensure accuracy and completeness when describing the technical properties of these products. For product information visit www.hellermann.tyton.com or call 800.537.1512
166-90269 价格&库存
很抱歉,暂时无法提供与“166-90269”相匹配的价格&库存,您可以联系我们找货
  • 20+6173.3465020+802.24213
