WWN2.00BK50
WWN2.00BK50
    TECHFLEX
    WELD WRAP 2" BLACK 50'
WWN2.00BK50 数据手册
EXTREME TEMPERATURES Technical Data Sheet WELDWRAP E  asy To Install - Cuts With Scissors Put-Ups R  esists Damage from UV, Gasoline & Engine Chemicals W  eld Splatter, Hot Slag, & Welding Spark Protection S  tays Flexible In Low Temps Nominal Size Part # Wall Thickness Velcro Width Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1” 1 1/2” 2” 2 3/8” 2 3/4” 3” 3 1/4” 3 1/2” 4” WWN1.00BK WWN1.50BK WWN2.00BK WWN2.38BK WWN2.75BK WWN3.00BK WWN3.25BK WWN3.50BK WWN4.00BK .04” .04” .04” .04” .04” .04” .04” .04” .04” 0.84” 0.84” 1.55” 1.55” 1.55” 1.55” 1.55” 1.55” 1.55” 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ Black Black Black Black Black Black Black Black Black 8.4 11.0 13.8 14.8 16.4 18.4 19.2 20.4 21.7 Protects Vulnerable Welding Hoses From Catastrophic Failure. Cut Cleanly Scissors Material Fiberglass Grade WWN Techflex WeldWrap (WW) is braided from fiberglass yarns with high temperature coating and velcro closure. Commonly used for protecting welding hoses against flame and abrasion, when dragging weld slag across the floor. This product will withstand continuous exposure to temperatures of 400°F/204.4°C, and intermittent introduction to temperatures of 750°F/399°C. The heavy duty hook and loop closure ensures a tight seal and allows WeldWrap to be installed easily over existing assemblies. WeldWrap also provides a high level of abrasion and penetration protection to increase the useful life of any hoses exposed to rough or abrasive surfaces. Wall Thickness .04” www.techflex.com 800.323.5140 • 973.300.9242 • fax: 973.300.9409 104 Demarest Road • Sparta, NJ 07871 ...bundles and protects hoses and cables on welding robots and static welding stations. Colors Available: Black (BK) EXTREME TEMPERATURES Technical Data Sheet WELDWRAP High Rating_________Non Flammable Maximum Continuous Mil-I-23053 Abrasion Test Machine 400°F (204.4°C) Taber 5150 Minimum Continuous -40°F (-40°C) Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 77°F Humidity 70% Material Destroyed Two Small Holes Worn Through 1,060 Test Cycles Pre-Test Weight 7,857.40 mg Post-Test Weight 6,602.20 mg Test End Loss Of Mass Point Of Destruction 1,255.20 mg 1=No Effect 4=More Affected 2=Little Effect 5=Severely Affected 3=Affected Aromatic Solvents_________________1 Aliphatic Solvents_________________1 Chlorinated Solvents_______________1 Weak Bases_____________________1 Salts___________________________1 Strong Bases____________________1 Salt Water 0-S-1926________________1 Hydraulic Fluid MIL-H-5606__________1 Lube Oil MIL-L-7808________________1 De-Icing Fluid MIL-A-8243___________1 Strong Acids_____________________2 Strong Oxidants__________________2 Esters/Keytones__________________1 UV Light________________________1 Petroleum_______________________1 Fungus ASTM G-21_________________1 Monofilament Diameter__________NA ASTM D-204 Flammability Rating___________VW-1 FMVSS-302 Approved Recommended Cutting__Scissor/Shears Colors_________________________1 Wall Thickness_________________.04 © 2014 Techflex, Inc. - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex, Inc. is strictly forbidden. Techflex product names and logos are registered trademarks of Techflex, Inc., unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s only obligations are those in standard terms of sale for these products and Techflex will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 06-14 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance Intermitten Exposure 750°F (399°C)
WWN2.00BK50 价格&库存
很抱歉,暂时无法提供与“WWN2.00BK50”相匹配的价格&库存,您可以联系我们找货
