166-11808
166-11808
    HELLERMAN(海尔曼太通)
166-11808 数据手册
Routing, Protection & Insulation HelaGuard Non-Metallic Conduits T E C H N I CAL D A T A S H E E T Standard Weight Double Cut Nylon Conduit HGDC Series A standard weight corrugated conduit with two slit openings that eases installation and maintenance of wire and cable bundles. The interlocking construction is excellent for retrofitting projects. PA6 material is highly resistant to solvents and oils, and offers UV and abrasion resistance. Conduit Size Euro Size Pitch Outside Dimension (OD) Minimum Bend Radius Weight mm mm lbs / foot 10.3 100 0.168 Inside Dimension (ID) HellermannTyton Part Number Manufacturer Part Reference in mm in FPADS16 0.63 15.8 0.41 in. mm (NW) F or C 3/8 16 12 F HG-DC0380 1/2 21 17 F HG-DC0500 FPADS21 0.84 21.2 0.55 13.9 120 0.04 3/4 28 23 C HG-DC0750 FPADS28 1.13 28.5 0.81 20.5 170 0.067 1 34 29 C HG-DC1000 FPADS34 1.36 34.5 1.05 26.6 180 0.091 1.25 42 36 C HG-DC1250 FPADS42 1.68 42.5 1.26 32.0 200 0.111 1.5 54 48 C HG-DC1500 FPADS54 2.15 54.5 1.70 43.0 240 0.158 Technical Properties and Performance Property Rating Material: Standard Weight Nylon Highly Flexible with excellent fatigue life IP (Ingress Protection) Rating with HG (FPA) Fittings Temperature Range-Static Temperature Range-Dynamic Displays self recovery if crushed Water and Dust resistant Abrasion Resistant High Impact Strength (at -25° C) Compression Strength: (Tested at 21mm size) Pull-off (Tensile) Strength (Tested at 21mm size) Country of Origin Polyamide Nylon 6 (PA6) Yes IP40 -40°C to +120°C -20°C to +110°C Yes Yes Yes > 6 Joules 60kg/100mm 15kg HG fittings Germany Fire Performance Flame Retardancy to UL 94 V2 Self extinguishing to EN61386 Yes Halogen Sulphur and Phosphorous free Yes halogenfree Warranty Policy HellermannTyton products are warranted to be free from defects in material and workmanship at the time sold by us; but our obligation under this warranty and that of the seller is limited to the replacement of the product, and neither we nor the seller are bound by any other warranty, expressed, implied or statutory. Under no circumstances are we or the seller liable for any loss, damage, expenses or consequential damages of any kind arising out of the use or inability to use these products. All are sold with the understanding that the user will test them in actual use and determine their adaptability for the intended uses. Every effort is made to ensure accuracy and completeness when describing the technical properties of these products. For product information visit www.hellermann.tyton.com or call 800.537.1512
166-11808 价格&库存
很抱歉,暂时无法提供与“166-11808”相匹配的价格&库存,您可以联系我们找货
