DWG4.00BK25
DWG4.00BK25
    TECHFLEX
    SELFWRAP4"X25'BLACK
DWG4.00BK25 数据手册
ADVANCED ENGINEERING HEAVY DUTY Technical Data Sheet Technical Data Sheet Put-Ups  Proprietary Abrasion Fabric E  xtreme, Oversized Hook And Loop Closure V  ery Puncture and Tear Resistant R  esistant to Water and Petroleum S  heds Surface Moisture Nominal Size Part # 1 3/8” 1 3/4” 2” 2 1/2” 3” 3 1/2” 4” 4 1/2” 5” 6” DWG1.38BK DWG1.75BK DWG2.00BK DWG2.50BK DWG3.00BK DWG3.50BK DWG4.00BK DWG4.50BK DWG5.00BK DWG6.00BK Wall Hook & Loop Thickness Width 0.05” 0.05” 0.05” 0.05” 0.05” 0.05” 0.05” 0.05” 0.05” 0.05” 1 1 1 1 1 1 1 1 1 1 1/2” 1/2” 1/2” 1/2” 1/2” 1/2” 1/2” 1/2” 1/2” 1/2” Bulk Spool Shop Spool 75’ 75’ 75’ 75’ 75’ 75’ 75’ 75’ 75’ 75’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ 25’ Available Colors Black Black Black Black Black Black Black Black Black Black BK BK BK BK BK BK BK BK BK BK Lbs/ 100’ 15.54 16.90 18.62 21.60 24.93 26.73 29.58 33.45 36.81 42.35 Heavy Duty Abrasion Sleeve With Easy On, Easy Off Hook & Loop Closure GATOR WRAP is made of proprietary extreme abrasion fabric. This protection sleeve is used for bundling and wrapping hoses and cables. The reusable sleeve features Mil-Spec extreme Hook & Loop closure which allows installation without disconnecting hoses and can reduce labor time by 70%. Gator Wrap (GW) is an excellent choice for applications requiring protection from the toughest abrasion. This heavy duty abrasion sleeve is being used in the oil field industry on frac hoses and on drill rigs, and in the timber industry to replace spiral wrap. Cut Cleanly Scissor Material Proprietary Abrasion Fabric Colors Available: Black (BK) Grade DWG Wall Thickness .05” Drawing Number TF001DWG-WD This is a non-expandable product. Be sure to match your application diameter accurately. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 HEAVY DUTY ENGINEERING ADVANCED Technical Data Sheet Technical Data Sheet ABRASION Maximum Continuous Mil-I-23053 Extreme!!! Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 69°F Humidity 50% No Major Wear 10,000 Test Cycles Slight Change. Coating Worn But Still Intact. 50,000 Test Cycles Pattern Continues. No Significant Change. 100,000 Test Cycles Pre-Test Weight 11,673.3 mg Post-Test Weight 11,673.3 mg Test End Loss Of Mass Point Of Destruction 0 mg CHEMICAL RESISTANCE 1=No Effect 4=More Affected 2=Little Effect 5=Severely Affected 3=Affected Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 1 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 4 Strong Oxidants___________________ 4 Esters/Ketones____________________ 1 UV Light_________________________ 1 Petroleum________________________ 1 Fungus ASTM G-21_________________ 1 RoHS___________________________ Yes Minimum Continuous -60ºF (-51ºC) PHYSICAL PROPERTIES Monofilament Diameter_________ NA Recommended Cutting________ Scissor Colors___________________________ 1 Wall Thickness___________________ .05” Specific Gravity__________________ 1.3 © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-28 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com 250ºF (121ºC) Abrasion Resistance
DWG4.00BK25 价格&库存
很抱歉,暂时无法提供与“DWG4.00BK25”相匹配的价格&库存,您可以联系我们找货
DWG4.00BK25
  • 1+4245.920151+544.87115
