WWH1.50SV
WWH1.50SV
    TECHFLEX
    SELFWRAP1.5"X50'SILVER
WWH1.50SV 数据手册
EXTREME TEMPERATURE Technical Data Sheet ADVANCED ENGINEERING Technical Data Sheet Put-Ups E  asy To Install - Cuts With Scissors R  esists Damage from UV, Gasoline & Engine Chemicals W  eld Splatter, Hot Slag, & Welding Spark Protection S  tays Flexible In Low Temps Nominal Size Part # Wall Thickness Velcro Width Bulk Spool Shop Spool Available Colors Lbs/ 100’ 1” 1 1/2” 2” 2 3/8” 2 3/4” 3” 3 1/4” 3 1/2” 4” WWN1.00BK WWN1.50BK WWN2.00BK WWN2.38BK WWN2.75BK WWN3.00BK WWN3.25BK WWN3.50BK WWN4.00BK .04” .04” .04” .04” .04” .04” .04” .04” .04” 0.84” 0.84” 1.55” 1.55” 1.55” 1.55” 1.55” 1.55” 1.55” 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 150’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ Black BK Black BK Black BK Black BK Black BK Black BK Black BK Black BK Black BK 8.4 11.0 13.8 14.8 16.4 18.4 19.2 20.4 21.7 Protects Vulnerable Welding Hoses From Catastrophic Failure. Techflex® Weld Wrap® (WW) is braided from fiberglass yarns with high temperature coating and velcro closure. Commonly used for protecting welding hoses against flame and abrasion, when dragging weld slag across the floor. This product will withstand continuous exposure to temperatures of 400°F/204.4°C, and intermittent introduction to temperatures of 750°F/399°C. Cut Cleanly Scissors The heavy duty hook and loop closure ensures a tight seal and allows Weld Wrap® to be installed easily over existing assemblies. Weld Wrap® also provides a high level of abrasion and penetration protection to increase the useful life of any hoses exposed to rough or abrasive surfaces. Material Fiberglass Colors Available: Black (BK) Grade WWN Wall Thickness .04” ...bundles and protects hoses and cables on welding robots and static welding stations. www.techflex.com 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 EXTREME ADVANCED ENGINEERING TEMPERATURE Technical Data Sheet Technical Data Sheet ABRASION High Rating_______________ Non Flammable Abrasion Test Machine Maximum Continuous Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 77°F Humidity 70% Material Destroyed Two Small Holes Worn Through 1,060 Test Cycles Pre-Test Weight 7,857.40 mg Post-Test Weight 6,602.20 mg Test End Loss Of Mass Point Of Destruction 1,255.20 mg Intermitten Exposure 750°F (399°C) Mil-I-23053 400°F (204.4°C) CHEMICAL RESISTANCE 1=No Effect 2=Little Effect 3=Affected Minimum Continuous -40°F (-40°C) 4=More Affected 5=Severely Affected Aromatic Solvents_________________ Aliphatic Solvents__________________ Chlorinated Solvents_______________ Weak Bases_______________________ Salts_____________________________ Strong Bases______________________ Salt Water 0-S-1926_________________ Hydraulic Fluid MIL-H-5606__________ Lube Oil MIL-L-7808________________ De-Icing Fluid MIL-A-8243___________ Strong Acids______________________ Strong Oxidants___________________ Esters/Ketones____________________ UV Light_________________________ Petroleum________________________ Fungus ASTM G-21_________________ PHYSICAL PROPERTIES 1 1 1 1 1 1 1 1 1 1 2 2 1 1 1 1 Monofilament Diameter__________NA ASTM D-204 Flammability Rating___ Non Flammable Recommended Cutting___Scissor/Shears Colors__________________________ 1 Wall Thickness__________________ .04” © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 08-26 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Abrasion Resistance FLAMMABILITY
WWH1.50SV 价格&库存
很抱歉,暂时无法提供与“WWH1.50SV”相匹配的价格&库存,您可以联系我们找货
